8th Ed. 8th Edition Carnosaur Build
Discussion in 'Lizardmen Tactics' started by The Lybithian, Jul 25, 2010.
  1. The Lybithian
    The Lybithian New Member
    Saurus Oldblood - 145 points
    Carnosaur - 210 points
    Golden Seal Sword (All attacks done at I10) - 15 points
    Sword of the Hornet (ASF) - 25 points
    Armor of Destiny (Heavy Armor; +4 WS) - 50 points
    Potion of Recklessness (Immune to Killing Blow and poison for one turn) - 5 points
    Dragoncurse Stone (2+ WS against Fire attacks) - 5 points
    Total - 600
    So he's a TON of points, but really, what is going to kill him?
    6 attacks, at Intiative 10 with always strikes first with re-rolls to hit? Then 5 Strength 7 attacks inflicting D3 wounds each and then on top of that D6 Strength 7 thunderstomp attacks. On even on top of all that he has a 2+ Armor save with a 4+ ward save. And 2+ WS against Fire Attacks. The only scary thing would be an Assassin of something else with ASF and I10 that can instakill the Carnosaur or the Rider. Which is why I put the immune to killing blow and poison for a turn.
  2. Ilnar3
    Ilnar3 New Member
    Ewwwww,,,,, I like it, it's nasty,
    Almost,,,, evil
  3. Tlax
    Tlax New Member
    golden seal sword and sword of hornet cant be taken together as both magical weapons or maybe you can but you cant use both at the same time
  4. The Lybithian
    From what I've read of 8th edition rules, which is almost all of them, the build is completely legal.
  5. Ilnar3
    Ilnar3 New Member
    Swop it for the potion of speed?
  6. Tlax
    Tlax New Member
    trust me it would be amazing if it was allowed by it says each model can only carry one of each type of magic item, so in this case the char has two magic weapons, but at least now no armies can have more than one dispell scroll
  7. Chicken Basket
    Chicken Basket New Member
    I think you have to look out for a few things still.
    -Something that makes you take initiative on a model's unmodified stat would still bring him down.
    -Also ranks and combat resolution could kill him on a multiple charge waiting around stubborn with ranks.
    -Few other things in magic (lore of death I'm thinking) could take him out, but I think its a solid build overall.
    Definitely would have to look at the sword rule though and maybe just take one and shift points to magic items?
    Can you take more than one enchanted or arcane item?
    What about multiple armor pieces, say an enchanted shield and hide of the cold one?
  8. Tlax
    Tlax New Member
    unfortunately you cant take more than one of each magic item from the categories which are magic weapons, magic armour, talismans, enchanted items, arcane items and magic standards.
    so no cold one hide and enchanted shield as they are both classed as magic armour
    also magic items cant be taken duplicate times in the same army unless stated so only one dispell scroll but their are other scrolls avaliable for magic defense now, same with power stones only 1 allowed
  9. wolfmage
    wolfmage New Member
    Mabe take a blade of realities allowing him a chance to kill enemies before he has to wound and the like which may not seem like much but since you don't get armour or ward against the slicing of your soul it's more likely to kill heavily armoured units that could otherwise bog him down.
  10. The Lybithian
    Here's the new legal build -
    Talisman of Endurance (5+ WS) - 30 points
    Shield - 5 points
    Total - 600
    Along with everything I posted above this bad boy now has a 2+ ward save against everything, since ward saves stack now, and a +1 armor save, but no more always strikes first.
  11. Trevy the Great
    Trevy the Great New Member
    I don't know where you are getting that Ward Saves stack. They do not.
  12. Gor-rok
    Gor-rok Member
    Page 44 of the rulebook spells it out; different ward saves cannot be combined, and you use whichever one is best.
    -edit: The only exception to this that I know of is the Chaos Warrior's Mark of Tzeench, which specifically does stack with other wards, or gives you a 6+ if you didn't have one already.
  13. sabernlw
    sabernlw New Member
    I hate to say but ward saves dont stack.... :( you can only take the best ward save you have. Tthe only time they stack is when you have magic resistance (#) then the wards save is stacked depending on what the number is... like if hou ahve a 6+ ward and magic ressit 1 then you would have a ward save of 5+ against magic only.
  14. lazylizard
    lazylizard New Member
    well you don't have to worry about killing blow too much because killing blow only effects those on regular 20mm/25mm bases. heroic killing blow can kill the carno but only 2 people can do that in this game. i believe an empire lord and a chaos named character has the heroic killing blow ability so you really don't have much to worry about.
    but overall, man that looks like a great build but its still too much points for me to invest in it.
    oh, here's a question for you.
    what happens if a cannon ball hits the carnosaur and kills it?
    now your lord is on foot, do you really think he'll survive?
    i'm not trying to be negative but just wondering what you would do especially since i for one keep my Carno away from my own infantry, its a long way til he gets to a unit.
  15. Trevy the Great
    Most Bretonnian Heroes have Heroic Killing Blow now it seems...
    If your Carnosaur does get killed, you go have one of the most powerful Lord Choices sitting there even if his mount is killed, and its not as if the Carnosaur's death destroys his defensive equipment.
  16. lazylizard
    true. but if it gets charged by lets say a unit of 25 ranked up infantry, most likely you would lose combat and have a possibility of running and getting overrun. that's all i was thinking.
  17. Gor-rok
    Gor-rok Member
    Killing blow works off of unit type and not base size now; even the Slann is vulnerable to regular KB as an infantry model now. The oldblood rider is vulnerable to it as well, and that will likely be an issue against things like Bloodletters.
  18. TheRolfgar
    TheRolfgar New Member
    This only adds up to 460, or am I still half asleep and missing something?
  19. Cougmeister
    Cougmeister New Member
    461 I believe, shield for an OB is 6pts not 5. It's pretty much impossible to get an Old Blood over 500points
  20. greenstuff777
    greenstuff777 New Member
    just to let everybody know you can take 2 magic weapons it says it on the top of the page
