So I was scouting about on the internet for something to make my life a bit easier making lists on the fly, found this and its absolutely godly! http://www.onlinecodex.de/build/Lamekh%27sOnlineCodex.jar Every army every unit every magic item all in drop menus, its a seriously good bit of kit. Try it out!
OMG!!!!! the best thing!!! so smooth. only one thing that i can rant about is that when youtake magic items or special abilitys like slann diciplines theydont write what does it do so you still need a book at your hand But over all an awsome thing
Yeah that is a little off, but you can write them up on the printable list at the side (my plan anyway )
i put the address in my browser but not much happens . can someone explain in lamans terms how to do it.
When you go to it it should start downloading it, you should get a window that pops up and click save. Then you'll have it
ok thanks i got it but when i go to open it it says something about windows not knowing what program created it . sorry not to good with computers
It is a Java file you need to have Java set up on your computer. You may need to download the file before Windows will see it properly as your internet security may prevent it being run without being downloaded first. If it still doesn't run then you need to get Java set up on your machine, I believe this is still a free download for the runtime files you need to run the .jar
