AoS Advice for Starborne without Salamanders
Discussion in 'Seraphon Discussion' started by Just A Skink, Apr 26, 2022.
  1. Just A Skink
    I'm interested in playing a Dracothian's Tail, or maybe Fangs of Sotek army, but I don't have any Sallies (or Razors). I considered Chameleon Skinks just because they can generate MWs at range as well.
    What models would you suggest instead of Salamanders in a DT or FoS army? Thanks.
  2. PabloTho
    PabloTho Well-Known Member
    For FoS I think 2 maxed out blocks of Skinks is a good start. Then bring all those force-multiplying heroes to juice them up - Starpriest for Serpent Venom and Hand of Glory, Priest for Curse and maybe even a Starseer for Control Fate (without Sallies your relying almost entirely on MW for damage so reducing saves helps a few more attacks slip through).
    You might also bring a Steg Chief as his CA for an extra melee attack can go a long way in getting your Skinks to pop off in combat phase, especially in tandem with the abilities mentioned above.
    All that still leaves you with a lot of points to play around with (not counting the mandatory Slann / Kroak). I often see a Solar Engine filling the gaps in this type of list, which gives you a tanky linchpin in an otherwise pretty soft army - also helps achieve monster-related battle tactics.
    Putzfrau, Just A Skink and Bowser like this.
  3. Dread Saurian
    Hear me out...2 carnosaurs. Hope for 1st turn. Yeet the t rex at their lines
  4. Killer Angel
    Engine of the Gods (possibly paired with a Starseer): drop them, activate the engine, then charge
    DREAD SAURIAN. Drop the beast along with a starseer, charge with 3d3 (+1 from constellation).
    Bowser and Just A Skink like this.
  5. Just A Skink
    These are all interesting suggestions, so far. Thank you!
    I kind of thought that a Starseer would become much more important in a Starborne list without any Salamanders.
  6. Killer Angel
    Yes, absolutely.
  7. Putzfrau
    Starseer is great, but so much of your damage is going to come from mortals it doesnt matter.
