aerosol spray
Discussion in 'Painting and Converting' started by aaron88, Sep 10, 2012.
  1. aaron88
    aaron88 New Member
    I wanna know can I prime/undercoat my models with other aerosol spray like the cheap ones sold in convenient store or I must use the ones from GW?
  2. Lord Tsunami
    Lord Tsunami Member
    other sprays CAN work, but they may also be useless. some sprays dissolve the plastic. some will not adhere properly to the plastic/metal. some sprays will have a too sleek surface and make it hard to paint over them.
    it doesnt have to be GWs sprays, but it is probably worth the extra money to buy a spray paint designed for miniatures (the army painter or similar), but if you feel like gambling, but a cheap spray and test it on some old model.
  3. n810
    I find Automotive grade primer in a spray can pretty decent.
    (USUALLY COMES IN WHITE BLACK, GREY AND DULL RED)
  4. aaron88
    aaron88 New Member
    maybe i should try spraying on the sprue 1st... I'm looking for grey colour to prime all my models. GW only have white or black. Sometimes it makes me wanna paint them straight without priming them. =.="
  5. Caprasauridae
    Not a very good idea, painting without priming that is. Army Painter has grey spray paint and it's bit cheaper (and at least in my mind, much better) than GWs. Pretty sure other ranges have grey spray too, but I'm not familiar with them.
  6. aaron88
    aaron88 New Member
    I'm just kidding. I'd never go on without priming my models 1st. :D
  7. lordberti3
    lordberti3 New Member
    Yeah army painter have a massive selection of primer and a few quid cheaper (in the uk it is anyway)
    Also, a bit off topic, why is it bad to paint without priming models first?
  8. n810
    Takes more layers paint to cover the model and paint tends to rub or ship off more easily,
    and generaly harder to paint.
  9. aaron88
    aaron88 New Member
    I still have lotsa old Citadel paints left... wonder how would the new paints do. Haven't try one yet...
  10. Caprasauridae
    And it has been scientifically proven, that models painted that way are much more prone to roll ones on their combat rolls and sixes on their characteristics tests. Also, they might cry at nights.
    EDIT: I think the new GW paints are rather good. If you see a colour you fancy from the new range, give it a try! Also, some new paints have better coverage than the old ones, so if you have troubles with a particular paint, a solution might be found there. The new metallics are rather fantastic!
  11. Arli
    Arli Moderator Staff Member
    I use inexpensive Krylon primer and it works fine. An automotive grade primer will cover a little better though.
  12. aaron88
    aaron88 New Member
    Yeah! Talking about the chemistry between bad dice and over layered painting. Anyway, will be heading to store to replenish some paints and at the same time trying to look for the desired primer. Lol!
