7th Ed. Apache Gunship
Discussion in 'Lizardmen Tactics' started by Enginseer, Jun 1, 2009.
  1. Enginseer
    Enginseer New Member
    Has anyone had any luck with a flying skink of raining death?
    I'm taking about skink chief on terradon, in a unit of 3 terradon riders - staff of the lost sun and spear?
    Seems like its good on paper, but I havn't seen him in anyones list. Is there a reason for this?
  2. kroxigor01
    kroxigor01 Member
    Hmm... Lets compare it to a High Elf Noble on eagle with Reaver Bow.
    Noble - Eagle, Reaver Bow, Dragon Armour, Lance, Shield (possibly Talisman of Loec as well)
    187 (197)
    Skink Chief - Terradon, Staff of the Lost Sun, Spear, Light Armour, Shield
    128
    Both characters have 3 S5 shots and can fly.
    Ways that the Noble is better:
    BS6>BS5
    30" range>16" range
    15" short range>8" short range
    3 WS6 S6 + 2 WS5 S4 attacks>3 WS4 S5 + 1 WS3 S4 attacks
    Noble is harder to take out (4+ save and a monstrous mount to hide behind)
    Ways the Chief is better:
    Almost 2/3 the cost
    Can hide inside a Terradon unit
    Drop rocks
  3. asrodrig
    asrodrig New Member
    That does sound pretty awesome. I'm going to have to try out that combo.
  4. strewart
    Most elf riders take the reaver bow and enchanted shield for a total 3+ AS rather than 4+.
    The skink combo looks ok and is pretty cheap, might have to consider it sometime. He is more fragile though.
  5. ninjakeso
    ninjakeso Member
    I'm going to try out a flying skink.
    Light armour
    Spear
    Blowpipe
    Venom Firefly Frog
    Shield of the Mirrored pool
    139 pts.
    I do believe that the venom is a great replacement for the staff of the lost sun, since you get poison on 5-6 with blowpipe.
    I also like the shield of the mirrored pool, since this is what's really dangerous for them terradons. Also, the spear for +1 charge and combined with poison i think you get a dangerous charge.
    I could probably switch the shield for the enchanted shield or something.
    The thing that I find really nasty is that you can "hide" the skink chief in the terradon unit, then let him charge out on his own to take out a mage or something and let the terradon riders drop their rocks and mind their own buisness.
    Anyways it's nice that the little chief's have gotten better. Now there's actually a point in taking a chief...
  6. Enginseer
    I think the main reason is there's actually room for him in your army. Personally with my high elves I need all the character slots doing other things.
    The mirrored pool is ok, I was considering an enchanted shield that way he has a 3+ save i think.
    I have noticed that skinks on terradons benefit from +1 toughness and +1 wound. Do you think a skink chief will get this bonus when the FAQ come out?
  7. Quillum
    Quillum New Member
    I just woke up, so I'm not thinking clearly, but can you have a blowpipe on your skink if he's on a Terradon? I know Terradons as a unit can't have blowpipes themselves, but does that extend to a Skink Chief if he wants one as a mount?
  8. strewart
    You can, there is no restriction. He is not a skink, he is a skink chief, and has access to both blowpipes and terradons. That would be like suggesting the chief cannot be given a shield since the terradon riders can't.
    @Enginseer, I don't think chiefs will get a stat boost for having a terradon.. The units need it because they are too weak otherwise, heroes are ok. There is a similar thing with pegasus knights in Bret armies, they get an extra wound and toughness for combined stats between mount and rider but paladins or lords on pegasi do not get that, so it won't happen for skink chiefs.
  9. Quillum
    Quillum New Member
    Ah, my apologies. I suppose being new to the game I should keep quiet about rules that I don't know about :oops:
  10. WheelR
    WheelR New Member
    I always want to bring one.. but pick something else in the end.. I be sure to use one on my next match. Only have to convert one .. Hmmm
  11. Dalkarius
    Dalkarius New Member
    Do keep in mind that on the Skink Chief weapon selection, it says to choose one, so having a spear AND blowpipe may cause an issue.
  12. strewart
    Hmm I will have to have a look when I get home.. Normally it is ok to have a ranged weapon and a combat weapon, you can't usually take several combat weapons. I would be surprised if the skink was any different, but GW may have messed up the wording.
  13. Caneghem
    Caneghem New Member
    Yeah, the chief has his pick of only one of jav/blowpipe/spear/halberd. I think if I ever went through the trouble of making a terradon chief I'd probably throw him a spear with the VotFF for magic/poison. The staff could then be taken as it is a ranged magic weapon only, and can't be used in h2h so the spear comes out on the charge. Now I'm not sure if this would conflict with the "Only 1 magic weapon per character" rule, since the spear becomes magic from the venom... I think it would be ok personally, since the 2 magic items choices are from different sections (VotFF and SotLS).
  14. strewart
    Whacked, it does clearly say one choice only. You would be fine taking a spear and the staff though since the staff is magical, even with venom that doesn't make a mundane spear count as a magic weapon, just gives it magic attacks.
  15. Enginseer
    This seems reasonable to me. With the spear he'd be a pretty effective mage hunter. Not a bad unit overall
