AoS Battalion Roles
Discussion in 'Rules Help' started by xoid, Jul 3, 2021.
  1. xoid
    xoid Well-Known Member
    Can a leader with fewer then 10 wounds fill the role of a commander, or can it only be a sub-commander? I can't tell from the information in section 26.
  2. NecridHydra
    NecridHydra Well-Known Member
    Yes. Commander can be a Hero with any number of wounds. It just make a difference so you can add Behemoth Leaders into battalions.
    Christopher and xoid like this.
  3. Zargore
    Zargore New Member
    Yes, seems like the distintion is the other way around to prevent stuff like 3 monsters/heroes filling a command entourage or warlord battalion
    xoid and Christopher like this.
  4. xoid
    What I figured, just wanted some other people's thoughts. Thanks.
  5. Kakalou1
    Kakalou1 Member
    Do a stegadon in Thunderlezard can be in a battalion for behemots ?
    Because he is a battleline but he gains also +2 wound
    I am thinking at Alpha Beast the Ghur battalion
  6. Zargore
    Zargore New Member
    So according to the new core rules:
    25.5.1 CONDITIONAL BATTLEFIELD ROLES Sometimes, the Notes column on a Pitched Battle profile will tell you to change the battlefield role of units of that type if certain conditions are met. For example, choosing a certain model to be your general can mean the battlefield role of certain units changes to Battleline. Where this is the case, unless noted otherwise, the unit loses all of the battlefield roles in the Battlefield Role column of its Pitched Battle profile and just has the battlefield role specified in the Notes column instead.
    It means youre Stegadons are Troops in Thunder Lizard when it comes to battalions.
    Kakalou1 likes this.
