AoS Battle tactic kill vs resurection
Discussion in 'Rules Help' started by Kakalou1, May 28, 2022.
  1. Kakalou1
    Kakalou1 Member
    Hi Guys,
    Quick question : your oppenent choose kill a Monster or kill thé général on an EotG with thé artefact where you come back on a 4+. He kills it but you succeed your roll. Is he score it ?
    Thank you for your help
  2. Killer Angel
    He doesn't score any point because the model wasn't killed in the first place.
    "The first time bearer is slain, before removing them from the battlefield, roll a dice. On a 1-3, the bearer is slain. On a 4-6, the bearer is not slain, all wounds allocated to them are healed, and any wounds that currently remain to be allocated to them are negated"
  3. Kakalou1
    Kakalou1 Member
    Thank you !!
    Another one : what if 2 salamanders run away during bravery, is the opponent score his 2 victory point ?
  4. Killer Angel
    yes, as the model is considered killed.
    Errata, august 2021:
    15.0 – Battleshock Phase
    Add the following sidebar note:
    Models removed from play as a result of their unit being split have
    fled. Models that have fled are treated as having been slain for rules
    purposes, unless noted otherwise
    (it talks about coherency, but every "casualty" due to battleshock is a "fled model" so it's safe to say it's the same)
    Putzfrau, Kakalou1 and Bowser like this.
  5. Putzfrau
    Also, the rules for priority targets read
    "Each time an enemy Priority Target unit is destroyed, and it was not destroyed by a friendly Priority Target unit, you immediately score a number of victory points equal to the reward value of that unit."
    Even if you killed it yourself (with a wild incarnate or something) your opponent would still get the points.
    Killer Angel, Bowser and Kakalou1 like this.
  6. Kakalou1
    Kakalou1 Member
    Thanks you very much for your help. I have few others question, dont want to open a New topic just for that.
    - Is the dread Saurian in TL has +2 wounds and +1 jaw attack ?
    - Is the ability on 3+ of the skink Priest has been faq or it still give run + shoot+ charge and +1 save ?
    - Is it possible to garnison a slaan + the bearer in the pyramide during déploiement ? And make a line at 2,9 with my saurus guard to protect the pyramide from a Monster charge ? (Or is it a Bad Idea?)
    - Any tip to keep the dread wholly within to give him order ?
    Thanks you
    Putzfrau likes this.
  7. Putzfrau
    Yes
    Still the same
    Yes, bad idea or not is entirely dependent on opponent/plan/board state
    Just keep a hero really close to him and/or just acknowledge he won't be getting orders sometimes. Probably easiest to keep something like an engine close.
    Kakalou1 likes this.
  8. Kakalou1
    Kakalou1 Member
    Thanks you very much!
    I have a new and tricky one :
    How the spell devolve from the Braychaman (move Closer an enemy unit of 2D6) work if the unit is in Garnison in the pyramide ?
