just a well rounded take all comers as I never know what I will be facing. Core: 30 Saurus, music, standard 10 skinks 10 skinks 10 skink skirmishers Heroes: Scar vet, shield, light armor, crown of command Lords: Slann Mage-Priest, one mastery, blood statuette, diadem of power Special: Temple guard full command, standard of leadership, curse charm of tepok 3 terradons 5 cold oneriders musician, standard Rare: 3 Salamanders Total:1941 points left:59 sadly I am only 1 point away from being able to also include 5 chameleon skinks.
id personally ditch the skirmishers, and then add the chameleon skinks instead, then u can add some more magic items
Special: Temple guard full command, standard of leadership, curse charm of tepok Standard of leadership means you can't use your general's leadership, so it's worse than pointless. I'd recommend using the flaming banner, in-case of flamable targets. How many are you taking? 16 to 20 should probably be fine at 2k. Not true! Because the Slann has to be in the unit, he benefits from the +1 Ld, (it's in the FAQs) both for him and his Inspiring Presence. It's a great combo as it makes the frog Ld 10. Also it can only be lost by wiping out the entire unit...
