8th Ed. Bloodroar against fearunits
Discussion in 'Lizardmen Discussion' started by Zwuppie, Apr 4, 2014.
  1. Zwuppie
    Zwuppie Member
    I was wondering, and discussing a lot.., if i give my carnosaur Bloodroar and i play against units which cause fear, the rulebook tells me that terror against fear becomes fear.. So against fear units they have to make a fearcheck without the 3D6 because thats only against terrorchecks if i'm right.
    Am i right when i say that Bloodroar don't work against Fearcausing units..
  2. Caprasauridae
    Yeah, that's how I would play it. So even if it is Terror that allows the opponent's Fear causing unit take the Fear test, it follows all the rules for the Fear.
  3. Mr Phat
    Mr Phat 9th Age Army Support
    Sometimes it helps to read the rule as its said in the book guys :D
    "Bloodroar:
    Enemy units must roll an additional D6 discarding the lowest result, for leadership tests to resolve Fear or Terror effects caused by this beast."
    Terror towards unit with "Fear" becomes a "Fear" effect instead.... Bloodroar states that Fear effects caused by the carnosaur is also resolved at an ekstra D6.
    So there you go: he rolls 3 dice and removes the lowest.
  4. Zwuppie
    Zwuppie Member
    Well, i've read them once and never before amd what i remembered was that they had to roll an additional dice and discard the lowest for terror, but thanks!! :)
  5. Caprasauridae
    Oops, yeah, should have checked the book before answering. Sorry about that. But if that's how the rule is written, then it's self-explanatory. Thanks for clearing it up!
