8th Ed. Book of Hoeth with Purple Sun
Discussion in 'Lizardmen Discussion' started by jormi_boced, Aug 12, 2010.
  1. jormi_boced
    jormi_boced New Member
    How can we hope to beat this?
  2. strewart
    There are a few items and a Slann ability that can help reduce the effect of the enemy mage which would be useful, but beyond that it is a matter of kill him before he can cast too much. The book is a 100 point item so the Archmage will be packing exactly nothing else, you are looking at 3 t3 wounds which isn't very much. Even if you suicide something into his unit and target all attacks on the mage, it is worth it.
    On Teclis, he is only t2 so even softer than a normal archmage.
  3. kermitthefrog3
    kermitthefrog3 New Member
    The item that makes them reroll on the misscast table is a nice one
  4. jormi_boced
    Except that the Book of Hoeth lets them get off irresistables without rolling on the miscast table.
  5. JohnMavrick
    JohnMavrick New Member
    A normal archmage, because of taking an item which doesn't allow them to take anything else leaves them open to any type of attacks that can target him specifically. Salamanders, stegadon bolt throwers (though these two allow a LOS roll) and our nice chameleon special character. You can snipe thise guy out of a unit because he'll have no armour or ward save unless his unit is carrying one.
    You can also use a suicide character, cheep but with the right kind of weaponry conbination to take out the mage, just as Strewart said. Even a skink chief could do this with cloak of feathers, magic armour and additional hand weapon. You should survive the elves ASF and then kill off the mage in your first round of combat. Your skink chief might get run down from resulting combat resolution.
  6. Vilicate
    Vilicate New Member
    Remember that he still has to match the spell's casting value to get it off with irresistible force. Try becalming him and that should help.
    Otherwise, the attack is still a template, you're you're going to get look-out-sir rolls for you characters; and it has to come from the mage's base, so they're probably going to be at least fairly close to you when they cast the spell. It's something that's going to be happening often; and a tactic (magess throwing lots of die at one spell). Also, there's the chance he's not going to roll that spell, since he doesn't know the whole lore. Not particularly likely, but the chance is still there.
  7. Bibamus
    Bibamus New Member
    a unit of spear evles fights in 4 ranks, 5 as a horde. since a skink or saurus for that matter will be in base contact with 3 elves, 1 of wich is teh wizard, he'll get 12 attacks from a non horde or 15 from a horde before he strikes back. since JSoD doesn't work anymore active magic defence s quite hard to pull off against high elves.
    becalming cogitation is your best shot porbably and in the case of a purple sun, hope it missfires or it rolls porely and move out of the way, if i understood magical votexes correctly they can't change direction.
    also, give him bigger targets to worry about and then revive them with teh slaan, or go for lore of light and get I10 all arround
  8. strewart
    Double 6 is still a miscast, but yes other doubles will get off safely..
  9. jormi_boced
    Yeah, my opponent doesn't double 6 though. He just double 5s and 4s and 2s it:)
  10. kroxigor01
    kroxigor01 Member
    Feedback scroll. Particularly on a Slann with Bane Head.
  11. Caneghem
    Caneghem New Member
    This has changed in 8th ed. Now you do not need to meet the casting value for it to go off irresistably.
  12. Bibamus
    Bibamus New Member
    neither did you in 7th. it was allmost the only way for the skaven to get their 13'th spell off.
  13. kroxigor01
    kroxigor01 Member
    Speaking of which. Beware the Grey Seer with Power Scroll! 4D6 of your models WILL die.
  14. Bibamus
    Bibamus New Member
    indeed, that might be even nastyer than the purple sun or pit of shades. you still have a chance of survival with those but since TG units are usually 17 models strong (16+slann) a grey seer can just cut that unit down, without any possibility of revival or "Lo,S!" and get brand new rats
  15. kroxigor01
    kroxigor01 Member
    And T8, regen, ethereal, MR3 all mean nothing...
  16. jormi_boced
    That is great except for the Book of Hoeth cancels the feedback scroll.
  17. kermitthefrog3
    Why is that?
  18. jormi_boced
    When he rolls doubles the spell is irresistable and the feedback scroll says it can be used instead of attempting a dispel, which you can't do if the spell gets off irresistably.
  19. ShivanAngel
    ShivanAngel New Member
    It specifially says in the high elf army book that you must still meet the casting value of the spell and roll a double for it to be undispellable.
  20. jormi_boced
    An archmage will rarely miss the casting value anyway uness he is just throwing his dice around willy nilly.
