i have a broken old type salamander, its off ebay and came snapped, would it be possible to glue back togther then fill in the gaps by painting the gaps with liquid green stuff??? please help, thanks
yes, you should be able to. Question though, where is it snapped apart at? EDIT: I have an old style Dark Elf war hydra that litterally lost one of it's heads - which is an all-metal model. It was such a pain to glue back as it was the head that was twisted the most and farthest away from the model making it heavy. If I had to redo it over again, I would have drilled and pinned then glued. - Lord Cedric
I think the Tail actulay came as a seperate piece, the legg shouldb't be too hard, just base the model and superglue the leg to the body and the base. I would probaly pin the tail though before glueing, those are notorious for falling off.
Other option would be to make scenic base that hides the busted leg. Putit behind a rock or a shrubbery.
