AoS Building a stegadon
Discussion in 'Seraphon Discussion' started by Canas, Dec 9, 2017.
  1. Canas
    Whenever I try to build a stegadon the howdah won't properly fit into the lil holes for the life of me. Anyone have any idea what I might be doing wrong? The end result doesn't look awefull as long as you don't look too close but it annoys me.
  2. Aginor
    Hmmmm I only built one Stegadon but the Howdah of that one snapped in perfectly as soon as I applied a bit of pressure.
    Hard to tell...
  3. OnlyPerfect
    OnlyPerfect New Member
    The first stegadon I put together I ruined the front lower section of thehowdah. Be careful because there is a front and back to that section. If you glue it backwards it will never set right. If I remember correctly the shields on the side peices are closer to the back.
  4. Canas
    That doesn't appear to be the problem, shields are in the right place when compared to the pictures on the GW site. There's also no spikes or anything that I can see blocking it. It just doesn't want to fit neatly in the holes :S
  5. Crowsfoot
    You have to push and twist and it should click into place if it’s assembled correctly, they are a bit tricky, I ended up glueing mine in place.
  6. Canas
    I can push all I want, the front bit of the howdah refuses to be in all 4 slots at once :(
    Seraphage likes this.
  7. Aginor
    Can you post a few pictures from various angles with the Howdah almost in position?
  8. Canas
    As you can see they're just slightly off, and completly stuck. Also, at this point i have given up and resigned to my fate as it doesn't look terrible. But it just annoys me that it keeps happening.
  9. Xasto
    Xasto Well-Known Member
    Still looks good, but yeah, I get ya man, pieces not properly fitting like they're supposed to make me rage beyond imagination!
  10. Killer Angel
    Especially when you consider that those models aren't exactly cheap... :meh:
    Xasto likes this.
  11. Seraphage
    Seraphage Well-Known Member
    By the way I had the exact same problem, I just pushed it to the point that it "broke" a bit in the inside and became less sturdy..
  12. tom ndege
    A bit risky... though for bigger stuff like the howdah it might be saver... also it's plastic so more forgiving than resin... so give it a try... but carefully!
    Another idea would be to snip off the bottom end and glue it to the steggy... the green stuff the part between the stump and the howdah...
    Also for the price of the model I'd expect it to fit exactly... maybe take it to the store and show someone... or email GW and complain about it... maybe you get an star priest for free or something...;):cool:
    Crowsfoot and Seraphage like this.
  13. Seraphage
    Well free aside, I was mad indeed. I love GW and pay for it. This is indeed something I am not willing to forget :p
  14. Canas
    The end result doesn't look too awefull so I'l leave it be for now. Though if this does keep on happening I'm going to contact GW to figure out what the hell the issue is.
