8th Ed. Building My First Lists (1000 points)
Discussion in 'Lizardmen Army Lists' started by scalesy, Dec 20, 2012.
  1. scalesy
    scalesy New Member
    1000 Point List
    Lords
    Saurus Oldblood
    shield.
    Heroes
    Level 2 Wizard
    Core
    25 Saurus Warriors
    Saurus Champion; Musician; Standard Bearer.
    11 Skink Skirmishers
    Skink Skirmisher Brave.
    Special
    14 Temple Guard
    Revered Guardian; Musician; Standard Bearer.
    A bit of clarification:
    14 Temple Guard because I intend to put the Oldblood in there. 11 Skink Skirmishers because that's the number of skinks I have and I want a tiny bit of shooty in the army.
    That's a total of 900 points, so I can add 100 points in some combination of the following this (given the models I have)
    • Magic Items on Priest / Oldblood
    • Up to 9 more Saurus Warriors
    • Up to 6 more Temple Guard
    • Remove some points somewhere and put in CoC
    Any thoughts? I'm going to play my first lizard games this weekend and play around with some lists :D
    I'll let you all know how they go!
  2. Ferocious
    Ferocious New Member
    for 1000, take out the oldblood
    you get a scar vet with some cool gears, and for 1000 pts, a scar vet is a toughnut to crack ;)
    your next purchase or conversion shoul dbe chameleons ;)
    try making the temple guard a bit bigger for the remainder of your points ;)
  3. scalesy
    scalesy New Member
    Why would you suggest them over something else?
    So if I add 5 Temple Guard, one more Saurus and make the OldBlood A Scar-Vet, it looks like this. Then I have 62 points of Magic Items I can split between my Heroes.
    1000 Point List
    Heroes
    Saurus Scar-Veteran
    Shield.
    Level 2 Wizard
    Core
    26 Saurus Warriors
    Special
    19 Temple Guard
  4. Ferocious
    because salamanders are one awesome unit!
    give your scar vet :
    light armour
    shield
    dragonhelm
    burning blades of chotec
    put dispel scroll on your skink priest
    if u got some points eft, maybe a nice banner on your TG
  5. scalesy
    scalesy New Member
    You said Chameleons the first time :p Salamanders were next on my list too.
  6. Ferocious
    that had to be salamanders XD maybe i psted chameleons becaus i was converting mine xD
  7. scalesy
    scalesy New Member
    If I put the Banner of Eternal Flame on the unit of TG to get flame attacks on the unit, would it apply to my SV in with them? and if so... should I skip the burning blade?
    EDIT: Just reread the flaming attacks rules. Screw that.
  8. scalesy
    scalesy New Member
    Should I be running a BSB?
  9. Rettile
    Rettile Active Member
    I wouldn't take the temple guard at 1000 points: they're quite expensive, and sauri are enough powerful in my opinion. I'd prefer to have points for chameleon skinks or salamanders. My advice is to drop the temple guards for another unit of 20 sauri, or make a sigle unit composed by 30 sauri and take more skink skirmishers or chameleon skinks. You also could drop your scar vet to have more points for the units. A skrox cohort, in example, would be great against almost everything (elite fighers and enemy heroes too)
