Has anyone run a OB on a carno in a unit of COs? If so or if I was to do so, what happens with the stupity and frenzy? If the stupity test is failed and unit moves forward 3.5", does then the OB/carno charge if in range after moving forward? Thus creating a 17.5" charge. Samuel
if a unit fails its stupidity test it moves forward M/2. after that they can not move the whole turn so the carnosaur stays here with the rest. if the carnosaur is frenzied adn the unit is not, if the unit does not declare a charge normally, you measure to see if the carnosaur must declare a charge, and if so he charges alone out of the unit.
Yea I know, just making sure that is what happens. Might run then together so the OB/carno has more CR, or later in the game get them together once the carno is frenzied.
One of my regular opponents runs a Chaos Lord on a Juggernaut with Chaos Knights in a similar fashion. It’s brutal once it hits.
