7th Ed. chaos
Discussion in 'Lizardmen Discussion' started by bryanabbo, Aug 22, 2009.
  1. bryanabbo
    bryanabbo New Member
    do chaos warriors also get to use daemons of chaos
  2. Eternity_Warden
    Eternity_Warden New Member
    No they do not. That is why they are two different factions.
  3. bryanabbo
    y is there a hordes of chaos army book that has both of them
  4. strewart
    Hordes of chaos is the old book. The new book, warriors of chaos, and indeed 7th edition has seen chaos split into 3 independant factions being mortals, daemons and beasts which do not combine.
  5. bryanabbo
    so that means i can5t get the lord of tzeentch (change) and the lord of change is also a lvl 2 wizard in the new book am i correct
  6. strewart
    I haven't really looked in the new book.... What is in that is what you can take, if it isn't in there then you can't take it.
  7. bryanabbo
    well did they take out everything the daemons of chaos have including the heroes like the lord of change
  8. Thebestlazyguy
    Thebestlazyguy New Member
    well the daemons can no longer be joined with the chaos warriors. thats pretty much final. the Daemons of chaos still have their lord of change model, yes, but unless you agreed with your friend beforehand on playing the older edition, you cannot take the lord of change. he simply cannot be used with the warriors of chaos
    the only daemonic figures we (the WoC) really have are a couple of freakish things in the special section, Galrauch, and Daemon Princes
