8th Ed. Competitive 750 (help wanted)
Discussion in 'Lizardmen Army Lists' started by Mr.Mclassypants, May 18, 2015.
  1. Mr.Mclassypants
    Mr.Mclassypants New Member
    Hello! I am not new to Lustria Online, but i am a new member. I have been playing Lizards for about 8 months and I recently used this list against his warriors of Chaos. I tabled his entire army except his exalted and won the game, but as i am by no means good at lizards, i feel the list could use improvement. Thanks!
    Tetto'eko (general) 185 pts
    22 Saurus Musician, Standard (6 wide with tetto) 272 pts
    5 camo skinks 65 pts
    Salamander hunting pack w/ extra 84 pts
    Total 745 pts
    Thanks again for the help!
  2. n810
    Welcome to Lustria,
    seems like a decent low point list,
    LD sees a bit low.
  3. Mr.Mclassypants
    Yeah looking back on the game I didnt have a problem with bad LD but i certainly could have been an issue.
    Do you have any recommendations?
  4. n810
    you could swap Teko-eko with a Saurus character for general,
    but then you wouldn't have any magic...
    at this point level you have to compromise a lot.
  5. Rettile
    Rettile Active Member
    I'd put Tetto in a skirmisher unit: more mobility and you don't have to put him in your main block risking to watch him die exactly when you were starting to need his buffs!
  6. LawGnome
    LawGnome Active Member
    One idea you may want to consider if you feel your leadership is low is to replace Tetto with a saurus character (scar vet cowboy, maybe? Oldblood with 1+/4+ and crown of command?) and replace your magic phase with a bastilidon. The bastilidon is great at this point level, because your opponent tends to have a few units, so it is easy to determine what the biggest threat is. You can toss all of your dice at it, and you don't care about miscasts. If you really want to, bring 2.
    miturian likes this.
  7. Lord Grok Of Xillaqua
    Lord Grok Of Xillaqua Well-Known Member
    Another option for booting leadership and maintaining your magic prowess can be to add The Prophet Of Sotek Tehenhauin. He is a level 3 wizard with Lore of Beasts (has a great bolt thrower spell and several buff spells for the saurus block, salamanders and Tehenhauin) who can also dish out 3 S5 attacks with poison and D6 S2 attacks with poison from his Tide of Serpents. While you have fewer spells and higher point cost, the dual caster/combat role would help the army have a stronger general in a small points game.
