8th Ed. doomwheel?
Discussion in 'Lizardmen Tactics' started by forlustria, Apr 16, 2013.
  1. forlustria
    forlustria Well-Known Member
    how can lizardmen deal with it. using only standard list stuff saurus,skinks etc
  2. n810
    ... Probaly the usualy asnswer to big scary stuf....
    Kill it with lots of skink poison shots.
    Ps. (5 units of 10 blowpipe skinks posible 100 shots)
  3. Arli
    Arli Moderator Staff Member
    Kill it quick though. I think the best way is the poison shots. However, you could also bog it down with skink cohorts. Once it takes a few wounds, it becomes as much a problem for the skaven player as for you.
  4. Stonecutter
    Stonecutter Member
    Skrox are the best unit to take it out if you don't have tons of shooting available. On average, 10 wounds are needed to drop it due to the 4+ armour save so that equates to ~100 shots (oops, I mean ~60 - bad math day)! However, every time it takes an unsaved wound from ranged fire, it has to take a control test and goes crazy on a 1 so you might get lucky. The DW is fairly easy to break in combat however with static res as it doesn't have thunderstomp and the S6 attacks from krox don't hurt either. The biggest problem is running it down since it flees a full 3d6 and can shoot again if it rallies.
  5. skillfull_dan
    skillfull_dan New Member
    skrox and magic missles.
    it is hard to get enough skinks nearby without losing them all. Random movement doesnt allow you to take a charge reaction so if you are close enough to shoot it, it is close enough to get a free charge on you. Random movement is probably the best way in the game of cutting down skirmishers, and poison is a great way to kill chariots and big monsters, this is why my skaven friend and I always hate playing each other.
    One in six chance of poison means it takes 60 shots to cause 10 wounds.
  6. n810
    You still get armor/ward/regen saves against poison.
  7. vict0988
    vict0988 Member
    Skrox may not be the best idea since, its lightning can be used in combat, which can will then on average kill a kroxigor per skaven turn. While the kroxigor may be able to kill it, there is a good chance at least one of them will go with it.
  8. Rettile
    Rettile Active Member
    i usually use temple guards with the razor standard
  9. newscales
    newscales New Member
    magic missile!
  10. JWK47
    JWK47 New Member
    I Metal it off with Searing Doom and then some poison. You can also just railroad the thing with terradons until it's dead.
