7th Ed. Few questions here
Discussion in 'Rules Help' started by SwiftChameleon, Feb 21, 2009.
  1. SwiftChameleon
    SwiftChameleon New Member
    G'day everyone, I'm new to this forum, been lurking around for awhile but decided to join this great community.
    Ok, first question- If say my Stegadon charges a unit and they fail their terror test and subsiquently flee, and i still mow them down and then redirect into another unit. Then in that combat i break that unit and they end up fleeing, am i then allowed to pursue that unit? The rules say that you cannot ovverun more than once, but does that first unit i charged down count as me ovverunning? Or should've i been allowed to pursue the second unit aswell?
    2. Can the EotG be used in close combat? I'm pressuming the burning alignment can't cause it wud count as a magic missile, but the other two options can still be used surely? or can all 3 be used?
    Help appreciated
    ~=SwiftChameleon=~
  2. strewart
    1. Yes, they are two different things so you can chase the second unit.
    2. Why do you presume it is a magic missile? If it doesn't specifically say it is, then it isn't. There are plenty of direct damage spells that aren't magic missiles. So yes you can use it in combat, since all magic besides magic missiles can be used from combat. The only stipulation is 'as long as the priest is alive he may use it'.
  3. SwiftChameleon
    Ok nice, thanks for clearing that up strewart....dam those archers that ran away from me.
