8th Ed. First Army: 2250pts
Discussion in 'Lizardmen Army Lists' started by Bishop_Sam, Aug 30, 2011.
  1. Bishop_Sam
    Bishop_Sam New Member
    Hey
    I am new to the Warhammer, and the lizardmen in particular. I love the idea of Slann (I mean magic space frogs… come on!), but not so much the temple guard deathstar. So what do you guys think of this 2250pt list:
    1x Slann Mage Priest (Life)
    - General
    - Battle Standard Bearer
    - The Focused Rumination
    - Focus of Mystery
    - Higher State of Consicousness
    - Feedback Scroll
    - Banehead
    - Standard of Discipline
    24x Saurus Warriors
    - Musician
    - Standard Bearer
    24x Saurus Warriors
    - Musician
    - Standard Bearer
    10x Skink Skirmishers
    - Javelin & Shields
    - Javelin & Shields
    6x Chameleon Skinks
    6x Chameleon Skinks
    6x Chameleon Skinks
    5x Terradon Riders
    1x Ancient Stegadon
    1x Ancient Stegadon
    The idea is the have the two stegs in the center, flanked by the saurus warriors, while everything else runs around being annoying. The Slann will sit behind in the blowpipe skinks, casting magic and basically making the stegadons unbreakable. I’m not sure if the Saurus blocks are too small, and whether terradons are worth it.
    I also have 60pts left that I don’t know what to spend on.
    Thoughts?
  2. Leokill27
    Leokill27 New Member
    Seems like a really solid list, though for you tactics I would change it a little.
    Saurus are really damn slow! Its better to have the faster stegs on the flanks, so once you get into combat with the saurus, you can make a flanking charge with the stegadons. If you have your saurus way out, you may well be too slow to get into combats that you can win!
    Other than that, sweet list!
  3. Bishop_Sam
    Thanks
    The reason I was using the Stegadons as anvils was that they are pratically unbreakable, but I think your idea would work better. If I am using the Saurus Blocks as anvils, I think they should be bigger (about 30?). What should I drop? some skirmishers, the terradons?
    Cheers
  4. Alucard698
    Alucard698 New Member
    I would consider dropping the terradons, or at least dropping a couple of them.
    All those Chameleons you have in there do what most people use Terradons for anyways. WM Hunting
  5. Bishop_Sam
    Fair enough, if I completely drop the terradons, I can buff both Saurus blocks to 30 and still have 80 points left. Is this worth it? What should I spend the rest of the points on? More Skirmishers?
