8th Ed. Friendly 1000pt vs Daemons
Discussion in 'Lizardmen Army Lists' started by Selantir, Sep 14, 2013.
  1. Selantir
    Selantir New Member
    Hey all!
    I'm doing a pair of battles later today, going in with a single 1000pt list against 2 seperate 1000pt Daemon armies (seperate times as well :p). Both will probably be a mesh of the different God's units... 1 being super heavy on the Daemonettes and the Tzeenitch caster unit if they can fit it I'm going to bet. I tested this list out on an Orc and goblin army the other day and annihilated them outright (lost 1 bastilidon to the lobber first turn (the one with the arc of all things)).
    List is as follows. Questions follow that :D.
    Scar Veteran: Shield, Lt. Armour.
    - Camped in with the Saurus Unit
    40 Saurus: Command
    10 Skink Skirmishers
    2 Swarm Bases
    Bastilidon: Ark of Sotek
    Bastilidon: Beam of Chotek
    Total of 1000 pts
    My strategy against the Orc/Goblin army was to set up the swarms and Ark to the left of the Saurus, the beam to the right, and the skinks to the right of that. He had a block of night goblin archers, with a lv 2 mage inside, 2 chariots, a group of 10 troll, a rock lobber and 2 groups of wolves.
    I ended with 8 dead suarus (to the trolls, 1 to arrows), 1 dead bastilidon (the ark one, he had first turn, and lobbed rocks onto it), and 4 of the skinks (to wolves). He only had 3 trolls and 3/4 of his archers left when we called it on turn 4 (his mage took a wound and lost a level).
    My Questions being...
    a) (The obvious) Should this theoretically be a decent all around vs Daemons as well? I realize there is a lack of casters for magical defense, but if I can engage the Tzeenich caster unit quick enough, or beam it to death, that would work yes?
    b) What should my biggest concerns be vs the new Daemon lists? I know in the old lists, Daemonettes in horde form were pretty dang scary...
    c) What should I prioritize for my swarms/Ark Basti?
    d) Skinks... should they be used as charge fodder for any daemonettes/khorn berzerkers to get some poison off on them first?
    e) Even though they seem to be very very pathetic vs High Elves and The Orc lists... is there any chance a Skink/Krox unit would perform better compared to the saurus?
    Thanks for any input, doesnt have to come in before this match... I can let you know how the list fares too if wanted.
