8th Ed. Friendly 3000 pts, no Grand Army
Discussion in 'Lizardmen Army Lists' started by Phenatix, Jan 25, 2013.
  1. Phenatix
    Phenatix New Member
    Lords- 540 pts
    1x Slann Mage-Priest
    Wizard Lvl 4, Lore of Light, Battle Standard Bearer, Standard of Discipline, Focus of Mystery, The Focused Rumination, Higher State of Consciousness, The Becalming Cogitation, Cupped Hands of the Old Ones, Divine Plaque of Protection
    Heroes- 579 pts
    1x Skink Priest
    Wizard Lvl 1, Lore of Heavens, Cube of Darkness
    1x Skink Priest
    Wizard Lvl 1, Lore of Heavens, Dispel Scroll
    1x Skink Chief
    Stegadon War-Spear, Light Armor, Shield, Ancient Stegadon
    Core- 1126 pts
    24x Saurus Warriors
    Saurus Champion, Musician, Standard Bearer
    24x Saurus Warriors
    24x Saurus Warriors
    10x Skink Skirmisher
    Special- 180 pts
    5x Chameleon Skinks
    5x Chameleon Skinks
    5x Chameleon Skinks
    Rare- 575 pts
    1x Ancient Stegadon
    2x Salamander Hunting Pack
    Total: 3000 pts
    Lords: 540 pts
    Heroes: 579 pts
    Core: 1126 pts
    Special: 180 pts
    Rare: 575 pts
    I think this format should be allowed, no individual points are listed now. This list is a bit core heavy, so I could potentially change out some of it for a mounted Scar-Vet, if need be. I gave the lone Slann ethereal, but are 2 Stegadons enough? I could include a baby in specials if that might do better, but I don't see much point in that. I went with 3 units of Saurus instead of 2 larger blocks in order to be more maneuverable.
    Thoughts?
  2. david l
    david l New Member
    How much experience do you have with Lore of Light? In my experience, I would rather have 2 Saurus units instead of 3, because then they and the Stegadons are easier to keep inside the 12" spell bubble range. Your experience may differ of course.
  3. Phenatix
    Phenatix New Member
    If I shrunk the Saurus down to 2x30 men groups each still with FC, I would save 162 points, which I could use to buy a mounted Scar-Veteran all kitted out. Maybe something like this:
    Scar-Veteran
    -Gambler's Armor
    -Dawnstone
    -Great Weapon
    -Cold One
  4. Scalenex
    I think your list is a little heavy on Skirmishing units (9 units), you can only put Light of Battle on one skirmisher unit at a time (practically speaking). I'd cut the Skirmishers back for more infantry.
    At the 3000 point level, most armies have three good solid blocks.
    I think with two Skink priests to direct Light magic missiles, you can afford to bunker the Slann in Temple Guard
    A Temple Guard block flanked by two big Saurus blocks should be able to handle about everything and you should still be able to keep your Stegadon in bubble range. If your Slann is deployed solo, it's harder to get bubbles. To help pay for the Temple Guard you could safely drop the Higher State of Consciousness and the Divine Plaque of Protection. If you were planning on using Light mostly without bubbles, you should probably stick with the lone Slann though.
  5. Phenatix
    Phenatix New Member
    What about something like this?
    -Wizard Level 4, Lore of Light, Battle Standard Bearer, Standard of Discipline, Focus of Mystery, The Focused Rumination, The Becalming Cogitation, Cupped Hands of the Old Ones
    1x Skink Priest
    -Wizard Level 1, Lore of Heavens, Cube of Darkness
    1x Skink Priest
    -Wizard Level 1, Lore of Heavens, Dispel Scroll
    30x Saurus Warriors
    -Saurus Champion, Musician, Standard Bearer
    30x Saurus Warriors
    11x Skink Skirmishers
    -Skink Skirmisher Brave
    10x Skink Skirmishers
    26x Temple Guard
    -Revered Guardian, Ironcurse Icon, Musician, Standard Bearer, Razor Standard
    6x Chameleon Skinks
    6x Chameleon Skinks
    6x Chameleon Skinks
    6x Terradon Riders
    1x Ancient Stegadon
  6. Scalenex
    Looks good to me, I'd consider dropping the Razor Standard in exchange for a few more Temple Guard. It's a little expensive for what it does considering that TG already give a -2 to enemy armor saves. The Banner of Eternal Flame or War Banner will more bang for your buck in my opinion.
    If you expect to play Vampire Counts, you'll want some characters with magical weapons but if not you should be fine against most opponents with this army
  7. Phenatix
    Phenatix New Member
    I like the Razor Standard since it turns them into a more meat grinder unit. Personally I'd rather have great weapons (since I'm stuck at I2 without using my shield anyways) but that's not an option (and if it was it'd be more than 1 point each). I don't really understand the point of the flaming banner. Fear isn't that good anymore, and there's so many items that give amazing wards vs flaming.... Are there really that many regenerating units?
    I will look at the warbanner, but does that still work when the Slann BSB is in the unit with it?
  8. Scalenex
    The anti-flame ward saves are something to be wary of. It's not that there are that many Regenerating units. It's that if they aren't there you are only out 10 points. If the Razor Standard is uneeded you are out 45 points. Flaming attacks also help when assaulting buildings.
    +1 CR for the BSB, +1 CR for the TG Standard, +1 CR for the Warbanner. They all stack.
  9. Phenatix
    Phenatix New Member
    I just don't like that with the flame banner you could potentially be paying points to activate your enemies ward saves. I will try it though, as that combination will save me some points and then I would have 48 points to spare on more a few more TG.
    Also thanks for the static res breakdown, that's good to know.
