AoS Help finishing 2k army
Discussion in 'Seraphon Army Lists' started by Gok, Aug 23, 2021.
  1. Gok
    Gok New Member
    Hi Everyone!
    I wanted to run this kind of Seraphon army, but i wanted to remove the Scar-Veteran on Carnosaur for a Scar-Veteran on Coldone. I also wanted to remove 10 Saurus Knights (2 x 5 actually) to use the 320 points spare for 40 Saurus warriors.
    Heres the army list, what do you think about it?
    Allegiance: Seraphon
    -Mortal Realm: Hysh
    -Coalesced
    -Koatl's Claw
    Leaders:
    Saurus Oldblood on Carnosaur (250)
    - General
    - Command Trait: Dominant Predator
    Lord Kroak (320)
    Saurus Scar-Veteran on Carnosaur (210)
    - War Spear
    - Artefact: Eviscerating Blade
    Skink Starseer (140)
    - Spell: Tide of Serpents
    Saurus Astrolith Bearer (140)
    - Artefact: Aetherquartz Brooch
    Skink Starpriest (120)
    - Spell: Hand of Glory
    Battleline:
    10 x Saurus Knights (200)
    - Lances
    - Lances
    - Lances
    Battalions:
    Firelance Starhost (160)
    Endless Spells / Terrain / CPs:
    Balewind Vortex (40)
    Total: 1980 / 2000
    Extra Command Points: 1
    Allies: 0 / 400
    Wounds: 105
    Treetrick likes this.
  2. Tyranitar
    Tyranitar Well-Known Member
    Is this intentionally a 2.0 list?
  3. Gok
    Gok New Member
  4. Treetrick
    Treetrick New Member
    Hate to be the bearer of less fortunate news, but Age of Sigmar within the last month or so moved to 3.0, so the point values are out of date. You can find the new point values here. With your list, Lord Kroak went up to 430 points so you might have to adjust your list. Also with Kroak's new model he has a warscroll that is stronger, but it won't be the warscroll/stats that you see in the current tome. Perhaps someone with the new Kroak stats can help you out in case you didn't know. Here's the new point values:
    https://www.reddit.com/r/seraphon/comments/o27f9n/aos_30_seraphon_points_updates_leaked/
    Also, there are no more faction battalions like "Firelance Host". Instead of having each race have unique battalions, all armies choose from a pool of core battalions that all armies can build. you can find those here. Good news is that you get different benefits and you free up enough points for new Kroak. Bad news is that your knights won't be as strong. Here's the new rules:
    https://ageofsigmar.com/core-rules/
    The last major change (as far as your list goes) is the concept of "reinforcements". Namely if you have a unit of 5 saurus knights that's ok, and if you reinforce them to a unit of ten you'll use one of your 4 total reinforcement points. Right now your list uses 3 of your 4 reinforcement points so you are in the clear, but it's something to be aware of.
    I hope that helps!
  5. Killer Angel
    Yeah, i did that tutorial... the contents and the tactics are still valid, but there are things that sadly are outdated, and it requires time (that i don't have) to fix it.
    Not only for the points value, but also the fact that in our battletome there are battalions that actually are no more playable in matched play.
  6. Gok
    Gok New Member
    First of, thanks for your answers ! It really helps me, i was really confused its hard to understand everything as a new player.
    So after a quick look, almost all the units in my list are more expensive now.
    Anyone have some 2k Koatls Claw list that i can base myself on to modify it?
    I really love the Seraphon, i really loved Kroq Gar in TWW2, and i wanted to build an army arount him (Oldblood on Carno) with the less skins possible :).
  7. Treetrick
    If you want some KC ideas check out Caleb's Youtube Channel, the video linked here talks about just that. He's a pillar of the Seraphon Community and his videos are linked all around this forum.
    Cuetzpal Pilli likes this.
  8. Tyranitar
    I wasn't sure if you just wanted to keep playing 2.0 but yeah, as others have said we moved to 3rd edition now. I'd also recommend checking out Caleb's YT video on koatls claw.
  9. Gok
    Gok New Member
    Thank you everyone for all your advices and good answers !
    I checked a lot of Caleb'S YT videos yesterday, he's really great, thanks again for the link i really like how he love and play Seraphon.
    So here's what i was thinking, for a readaptation from my list, based on Caleb's KC videos :
    - Constellation : Koatl's Claw
    - Grand Strategy: Hold the Line
    - Triumphs: Inspired
    Leaders:
    Loard Kroak
    (430) in Battle Regiment
    Saurus Scar-Veteran On Carnosaur (215) in Warlord
    - General
    - War Spear
    - Command Trait: Dominant Predator-
    - Artefact: Amulet of Destiny (Universal Artefact)
    - War Spear
    Skink Starpriest (130) In Warlord
    - Spell: Hand Of Glory
    Battleline:
    5 x Saurus Knights
    (110) In Battle Regiment
    - Lances
    5 x Saurus Knights (110) In Battle Regiment
    - Lances
    - Lances
    30 x Saurus Warriors (315) In Battle Regiment
    - Spears
    - Reinforced x 2
    Behemots:
    Bastiladon with Solar Engine
    (235) In Battle Regiment
    Core Battalions
    Warlord
    Battle Regiment
    Additional Enhancements:
    Artefact
    Total: 2000/2000
    Reinforced Units: 2/4
    Allies: 0/400
    Wounds: 120
    I like his list a lot. I was just wondering about Kroak survability without Astrolith Bearer, if a Scar vet could be on cold one to add a Oldblood on Carnosaur. And if a Starseer could be needed for those charge buff?
    Thanks a lot again !!!
    A friendly baby Saurus.
  10. The Big Skink
    The Big Skink New Member
    Cool list. I'm a baby Saurus too.
    I'm concerned that without AB, Kroak you will need to be extra aggressive with Kroak. Being aggressive without Guard is risky.
    Have you considered dropping one knight unit for guard?
    Maybe sub Priest for Starpriest and add cogs to make the points work? Priest hangs with Bastiladon to make her work better and or heal ScarVets? Cogs to help a little with charges.
  11. Tyranitar
    If you're looking to just run kroak as support to generate CP, heal, etc you'd be better off running a normal slann plus a starseer. I'd also recommend cutting a knight unit for guard probably but not necessary if you make the swap to normal slann who can just sit back more defensively. Oldblood carnos are unfortunately just not worth their points over a scarnosaur, especially in KC where their command ability is even more redundant
  12. Gok
    Gok New Member
    Thanks a lot !
    I wanted to use Kroak as i like his new model a lot!
    I am gonna do some theorycrafting, i'll send back a new list about tonight. I will try to include a Starseer for sure, an Astrolith Bearer, will remove a unit of knights for a units of guards, and i'll see about replacing Kroak for a regular Slann OR remove one Scar Vet on Carnosaur to have one Carnosaur on Coldone.
    Lemme just calculate all of this, and i'll be back!
    Thanks for the patience and advice!!!
