So Tetto'eko's Herald of Cosmic Events doesn't seem so bad Unfortunately when I used him, I totally forgot about the rule, but anyhow: Rolling a 1 means all wizards re-roll 6's for casting Well at least if you can roll 6 power dice without worrying about miscasting too often Rolling 2+ means all wizards re-roll 1's for casting As long as those 1's dont turn into a heap of 6's then well done, it will save you spending lots of power dice on spells if you are worried about not meeting the casting value Other uses for this little trick? Maybe it could help get a mistcast for a skink bomb or something
