8th Ed. How to use a Slaan Properly
Discussion in 'Lizardmen Tactics' started by Kawell, Apr 8, 2013.
  1. Kawell
    Kawell New Member
    I have played a few games with 1 slaan, but im not sure if im using him right or to his full potential. I give him lore of life so he can take out huge chunk of goblins with the dwellers below spell. I usually have in a temple gaurd unit but the temple gaurd never get in combat and it seems a waste of 500p on the TG alone. Should I send the slaan alone or just put him into a saurus unit and forget the temple gaurd? Are the temple gaurd worth 500p for 30? Please help.
  2. newscales
    newscales New Member
    Definitely don't take 30 TG. 20 is one of the most common configurations. 6 wide, it allows him to be encompassed by the unit. Some people go with 16. Fewer than that, and the unit isn't likely to hold up long in combat.
    Now, I never ever ever ever want to see my slann get close to melee combat. That's just how I play, though. So putting any extra points to a unit that I hope to never see combat is a huge waste for me. I've take to putting the Slann in a saurus warrior block and then if I need to, moving him out of the unit, but withing 3" to keep the 4+ LoS.
    Then again, there is higher state of consciousness and the talisman of ensurance if you want to get a 2+ ward save on spells and can only be hit by magical attacks. for an 80 point investment, he is nearly untouchable.
  3. Lawot
    Lawot Active Member
    I used to have that problem, as well...I wanted the protection of a Temple Guard unit, but the points always seemed like a waste when they never saw combat. So I started building them into my list and strategy as a main combat unit, counting on them taking charges and such, and basically replacing a Saurus unit. I'm not too terrified of getting my Slann 'near' combat, so I generally throw the TG into a situation where I need a practically unbreakable unit, and trust them to protect their Slann.
    This allows the points spent on the TG to directly affect the game, and means that I don't feel bad about throwing a few more models into the unit - they'll see action eventually!
    Of course, the other option is the lone Slann. I played him for the first time recently, and he did quite well. In fact, he liked being alone so much, that as soon as I moved him into a unit of Saurus, he nuked them with a miscast.
  4. jg0124
    jg0124 New Member
    I run mine solo. Every time I use tg I miscast and blow them up. Unit of 26 and 2 turns and I have 6 left.
  5. Irish_Lizard
    Irish_Lizard Member
    forget the temple guard and stick him in a skink bunker as its cheap, mobile, gives him the same look out sir roll and most importantly allows him to leave if the unit gets smashed by magic or shooting.
