8th Ed. How to use skrox units?
Discussion in 'Lizardmen Tactics' started by PlasmaDavid, Jun 4, 2013.
  1. PlasmaDavid
    PlasmaDavid Active Member
    I've used skrox units a couple of times now, mainly 20 odd skinks with 2 krox... and I just can't see how to use them. They're squishier than Saurus and it feels bad charging them out ahead of the Saurus battle line.
    Am I doin it rong? Do I need bigger units? Should they be dedicated flankers? I just can't "feel" their place, only that the points could have been spent on more Saurus instead.
  2. Scalenex
    With 20 Skinks/2 Kroxigor, I'd recommend making it a dedicated flanker.
    I'd recommend making the unit bigger if you want it to take things down by itself. In points terms, Skroxigor will win against most units. In terms of CR they will lose against most things. Thus you need extra Skinks to maintain Steadfast.
    A very handsome forumite wrote something that may help
    http://www.lustria-online.com/threads/choosing-the-size-of-your-skink-cohorts.9790/
  3. Dog On Todd
    Dog On Todd Member
    In addition to the handsome writeup o_O I found Skrox to be allstars against low toughness elite units.
    Example: Elves.
    My Saurus were dying just as fast against Sword Masters and things like that as my skinks, but skinks cost a lot less. So its point denial while also still winning combat with sheer numbers. The high initiative helps too for getting your attacks in first before the Krox finishes things off.
    This was the only scenario where I would charge a Skrox against something alone though. Too expensive for flanking chaff clearers, so they are meant for combo charges and utility blocking/clearance. A handy unit if you can fit it in. Just takes some practice using
  4. Stonecutter
    Stonecutter Member
    Scalenex's treatise on skrox covers just about every eventuality short of a new AB that provides some red-crested skink option with a mighty T3!! Just to highlight a few of the key points in the tactica, the skinks are extremely squishy and thus will give up combat resolution to just about anything. However, the unit causes fear, moves quickly, is immune to stomp and can dish out S6 hits. Another often forgotten quality is the ability of skrox to shoot - a key reason to give them a musician to permit a swift reform. A typical 3 krox block that reforms from 6 to 12 wide can dish out 18 poison shots and will retain 2 full ranks until the 19th skink dies. Given these qualities, skrox can be effectively used as follows:
    1) Monster & chariot killers - between poison shooting, steadfast, S6 hits and immune to stomp, they can bring down almost any of the big nasties (hydra, chimera, HPA, gorebeast chariot, etc.) that will lay waste to TG or saurus.
    2) Flankers - the speed & charge range makes them good flank protectors for the main saurus/TG blocks as well as excellent in providing support charges. They can be used to screen sallies from enemy troops , allowing the sallies to get into ideal firing positions.
    3) Gunlines - The speed and relative hitting power against a gunline makes them perfect. By turn 3 they will be well into the opponent's rear area and can take out any "war machine", including the hellcannon.
    4) Monstrous cav and S6 troops (irongutz, white lions, etc.) - Saurus/TG can't get through the 1+ save of much of the recent MC and get stomped while S6 kills them on 2's anyhow. Might as well be a skink dying and at least the krox have a good chance of killing some high value troops while the skinks take one for the team!
