Kharn's lizardmen
Discussion in 'Painting and Converting' started by Kharn The Betrayer, May 2, 2012.
  1. Kharn The Betrayer
    Kharn The Betrayer New Member
    [​IMG]. Is this enough contrast? I'm just starting out painting and have only done a sallie so far, what crest color would you say to go with?
  2. Kharn The Betrayer
    Also what did I just do wrong uploading?
  3. Moniker
    Moniker Member
    You need to do [ PIC ] on our forums instead of [ IMG ]
  4. Kharn The Betrayer
    Aah, thanks, also what crest color should those colors go with?
  5. strewart
    Colour choice is good I think. I would probably go with either red or yellow for the crest. Red to give that bright lizard look, yellow to fit the rest of the model more subtly.
    Try to get a lighter shade of green to highlight/drybrush onto the skin and maybe a wash as well to add some depth and make the detail come out better.
  6. Kharn The Betrayer
    Thanks, I'll have a pic of my Sally up tommorow
  7. Lord Tsunami
    Lord Tsunami Member
    to post images in threads you should use [pic] tags rather than [​IMG]
  8. Kharn The Betrayer
    Does anyone know if the new orange wash is darker or lighter than blazing orange?
  9. strewart
    Washes naturall shade and darken base colours so I would say there is a very strong chance it is darker than blazing orange...
  10. Kharn The Betrayer
    Says my pictures can only be 1 pixel?
  11. strewart
    Thats because you have to use [pic] not . We disabled the img tags by restricting their size to 1 pixel, but the pic tag works exactly the same.
    [quote="Lord Tsunami"]to post images in threads you should use [pic] tags rather than [img]. apparently it is to stop spambots (though i havent seen any of those on any of the other forums that still use [img] tags...)[/quote]
    The reason we did it is because we were getting loads of bots on this forum posting very large and very explicite and inappropriate images. It was a direct response to a very bad bot problem we had for a long time.
  12. Kharn The Betrayer
    Thanks, this still needs some shading/ hilighting, but it at least has my color scheme. a54a8525.jpg
  13. Kharn The Betrayer
