AoS Kroak+2 slanns
Discussion in 'Seraphon Army Lists' started by EricM, Dec 18, 2023.
  1. EricM
    EricM New Member
    So I bought the 2 new boxes and Kroak and now have 2 slanns +kroak.
    Anyone ever tried a list with that much magic? I know it won’t be competitive but I thought it could be fun to try before I get rid of one of the two slanns
  2. Just A Skink
    Actually, I was thinking of a list like this recently, too. It would probably lean too heavily into slanns, since miscasts would ruin your day. But it might be fun to try it.
    Allegiance: Seraphon
    - Constellation: Dracothion's Tail
    - Grand Strategy: Spellcasting Savant
    - Triumphs: Indomitable
    Leaders
    Slann Starmaster
    (290)*
    - General
    - Command Trait: Lord of Celestial Resonance
    - Artefact: Spacefolder's Stave
    - Spell: Comet's Call
    - Spell: Drain Magic
    Slann Starmaster (290)**
    - Spell: Stellar Tempest
    - Lore of Primal Frost: Hoarfrost
    Lord Kroak (410)**
    - Spell: Mysticl Unforging
    Saurus Astrolith Bearer (140)**
    Battleline
    5 x Saurus Guard
    (140)**
    10 x Saurus Warriors (180)*
    - Clubs
    - Clubs
    - Clubs
    10 x Skinks (90)*
    - Boltspitters Celestite Daggers & Star Bucklers
    10 x Skinks (90)*
    Faction Terrain
    Starborne Realmshaper Engine
    (0)
    Core Battalions
    *Battle Regiment
    **Warlord
    Additional Enhancements
    Spell
    Total: 1990 / 2000
    Reinforced Units: 0 / 4
    Allies: 0 / 400
    Wounds: 132
    Drops: 5
    -You have to set up fairly "castle" since your Slanns are better near your Astrolith. Astro is arguably the most important hero on the field!
    -Put your general as far back as you can (probably next to the Realmshaper) and cast Celestial Equilibrium, Drain Magic (if there are enemy wizards), and Comets Call every round for summoning points.
    -2nd Slann is near the front casting Stellar Tempest, Hoarfrost, and Mystic Shield/Arcane Bolt.
    -Place Kroak and the Guard behind a unit of Warriors on the front lines to stretch his range as much as possible for Celestial Deliverance x4 or other spells as able.
    -Saurus Warriors are a decent anvil and are set up to hold off the enemy long enough to cast/summon multiple turns. However, at only 10, they will last probably 1-3 combats at best (depending on what they're fighting).
    -To me, the Skinks are mostly here to help zone out your back field as long as necessary (I play against Soulblight often and having skeletons, zombies, etc. pop up behind your lines is not fun).
    -Summoning priority will likely be Skinks (as it usually is), but Warriors and even Guard are great late game if you can.
    OPTIONS
    -You could try to get very cagey/aggressive if you can go first with Dracothian's Tail. Set up all models except Guard and one unit of Warriors. First round, you hero phase teleport Kroak up the field (if you can keep him within Astrolith, all the better) and start blasting. At the end of the movement phase you teleport in the Guard, to protect Kroak, and the Warriors to hold off the enemy for a combat or two. That said, once Kroak goes down, you will struggle to recover and win. But... YOLO!
    -An alternative would be to take out the Guard or the Skinks and add a 2nd Astrolith. That will allow you to spread out if you need.
    -You could take out the Skinks to reinforce a unit of Warriors or add another unit of Guard.
    If you want all the casting.
    Leaders
    - General
    Lord Kroak (410)**
    Skink Starseer (150)*
    - Spell: Cosmic Crush
    - Spell: Celestial Harmony
    - Lore of Primal Frost: Merciless Blizzard
    Battleline
    - Clubs
    - Clubs
    - Clubs
    Core Battalions
    *Battle Regiment
    **Command Entourage - Magnificent
    Spell
    Total: 1970 / 2000
    Allies: 0 / 400
    Wounds: 114
    Drops: 4
  3. EricM
    EricM New Member
    Wow thank you so much for the great answer! I lean towards the first.It’l be a while until Intry it but will definetly get back to you as to how it went. Thanks again!
