8th Ed. Making an army
Discussion in 'Lizardmen Army Lists' started by Trexler, Nov 6, 2013.
  1. Trexler
    Trexler Member
    i would like to create an army that is not big on magic and uses no Slann. i would like this army to end the game quick by over running and overwhelming the enemy. if you could help me with a list of units that can achieve this goal i would be greatly appreciated.
  2. MHK Pathfinder
    MHK Pathfinder Member
    Well unfortunately, there's no magic button we can push to overwhelm opponents and curb-stomping them into the ground. That's more dependent on the tactics you use and the luck of your rolls.
    That said, it's perfectly possible to build hard hitting low-magic lists that would be a lot of fun to play.
    A mix of Skrox units, Saurus Warriors, Cold One Riders, and Stegadons will give you a hard hitting list with some good movement/overrun opportunities. Headed up by Oldbloods or Scar-vet Cowboys will give you high-leadership heroes that can get in the fight.
    I played a small 800 pt tournament a few months ago, and decided to go with a no magic list. I stuck to a block of saurus warriors, a skrox unit, a scar-vet cowboy, cold one riders, and a unit of chamo skinks. It worked well for me (except vs DE, but that was more my fault tactically than anything).
  3. Trexler
    Trexler Member
    thank you for that helpful tip....i plan to use Stegadon and Terradon/Ripperdactyl Riders..i think they will work will in an army together
