My Steg Conversion Model Question
Discussion in 'Painting and Converting' started by Lord Cedric, Jun 26, 2011.
  1. Lord Cedric
    Lord Cedric Member
    Hello everyone! I found this dino-toy at Walmart the other day for only a buck and thought I might try to do a conversion for a Steg.
    The dimensions are a bit larger than the GW model, but not by much I don't think (according to measurements I found online). Width is 2.5", head to tail is about 8", and 3" total heigth with a 2.75" height to the back peak.
    So my questions are, what are your opinions and recommendations? I know the scaling is a bit off, but I thought it was kinda close for a $1 Wal-Mart toy.
  2. dictator
    dictator New Member
    Who cares! Unless you are going to a specific Games Workshop sanctioned tournament you're good. I want to see the progress now!
  3. Lord Cedric
    Lord Cedric Member
    Hah! Alright. then. I'll get a start on the conversion this week. I'll post updates when I have them. Thanks!
  4. TheRolfgar
    TheRolfgar New Member
    If its feet fit (or at least mostly fit) on a chariot base (50X100mm) It should work fine. The current GW steg hangs over the base as well.
  5. strategiccommand
    strategiccommand New Member
    As someone who constantly converts items and takes them to GW sanctioned events...Just abide by their rule... MAKE IT LOOK GW. My Thunder Lizard project is now officially approved by GW and its staff... As long as you add enough bits and pieces to make it look like the Steg you are good to go.
  6. n810
    Funny I did a conversion with that same toy Steg...
    Definitely give it a good coat of primer before you paint it
    or it will stay sticky for some reason...
  7. strewart
    You are missing out on an amazing sight if you do not check out his thread on it here. Its 13 pages well worth going through.
