8th Ed. Need advice for my 1st Lizardman list 1500
Discussion in 'Lizardmen Discussion' started by ElSabrone, Nov 2, 2012.
  1. ElSabrone
    ElSabrone New Member
    Hi all,
    i new to Lizardman army and on sunday am going to have my 1st battle with lizzardman against DE army.
    Points are 1500
    What can i use:
    Skinks
    Saurus Cavalery
    1 Stegadon
    2 Salamanders
    Temple guard
    What do you think is good idea tu run on such points.
    What are my strengths and weakneses against DE.
    Thanks a lot for any advice....
  2. Scalenex
    Well for starters, definitely take the Salamanders. They are fantastic at roasting elves of any type. The Stegadon should be okay, an Ancient Stegadon is overkill since you only need S5 to wound elves on a 2+.
    Saurus and Temple Guard blocks will be a good backbone to your army. It’s debatable whether taking Temple Guard without a Slann is a good idea or not since Saurus are nearly as good and a lot cheaper.
    http://www.lustria-online.com/threads/saurus-vs-temple-guard.8094/
    Temple Guard have a couple advantages, they can wound elves on a 2+ instead of a 3+ and they force DE Core (but not DE Specials) to roll 4+ to hit them rather than 3+. If you choose to take Temple Guard make sure to take a Banner of Eternal Flame. Ten points is cheap for Hydra insurance.
    I wouldn’t field the Kroxigor without Skinks. By themselves the Kroxigor wouldn’t last long. I wouldn’t field a Skroxigor block without A LOT of Skinks since you will need to maintain steadfast to keep your Skroxigor block in place. If they can maintain Steadfast they will negate enemy Stomps and not have to worry about Fear. If you go Skinks without Kroxigor I’d suggest having them skirmish and running with javelins and shields. Then sending the skirmishers against the low armor save elite targets (especially Witch Elves) to whittle them down with poison shooting.
    I have not used Saurus Cavalry against elves of any type yet so I can only guess if they’d be good or not. I guess they’d be okay, neither good nor bad. Saurus Cavalry use depends on your ability to make clever charges.
