8th Ed. Need extra help with this 2000points Carnosaur army list
Discussion in 'Lizardmen Army Lists' started by Fentesie, Feb 29, 2012.
  1. Fentesie
    Fentesie New Member
    So telll me what do you guys think of this setuup...
    Lord: Saurus Oldblood+shield and light armor equipped: revered blade of tzunki+glyph neckles. 466pts
    core: 2x 10x skink skirmisher brave=260pts.
    core: 27x saurus warrior+spear+standart bearer+musician=342pts.
    Heroe: skink priest on EotG lvl2+stegadon warspear=350pts.
    Special: 6x Chameleon stalker=108pts.
    Heroe: skink priest lvl2+dispell scroll+power stone=145pts.
    Special: 4x kroxigor=210pts.
    Special: 3x terradon rider=90pts.
    This comes to a total of 1971 pts if I'm correct? So any suggestions or ideas for this army?
    Any help is welcome ;)
  2. Omar
    Omar New Member
    You can probably get him a better weapon than blade of tzunki. blade of tzunki is a bit over priced and with a halberd you get the +1 S and a -3 to armor which is just as good for mowing enemy core.
    I think the warspear says Skink Chief only. I'd check on that.
    I like spears but if I feel like I can get something that'll produce more wounds than having an extra 5 attacks I usually go for that. In this case if you give up spears you get an extra 27 pts, add that to your left over points and you have an extra 56pts left over. I usually get spears if I have around 30 pts left over and I've already given my characters the items I wanted.
    I'd either take the Krox in a unit of skins or trade them in for sallies. The reason is that sallies will cause a hell of a lot more wounds than the lone kroxies will for just about the same points.
    All of these suggestions are pretty standard choices for LM in this edition. If you go to other posts you'll suggestions along these lines. Sometimes though you just want to play a certain unit or setup you'd think you'd enjoy and ultimately I'd go with that! Good luck!
  3. Arli
    Arli Moderator Staff Member
    Yea, a skink priest can only be on the EOTG. You need a chief for the warspear.
