im facing my friend again and i need a total army destroyer and some tactics to use this is what i came up with?i also need help with magic items. LIZARDMEN LIST SLANN:Focus of mystery,higher state of consciousness,trancendent heALIng,unfathomable presence SKINK PRIEST: ancient stegedon engine of the gods level 2 CORE: SAURUS:=20 spears SAURUS:=16 spears SKINK SKIRMISHERS:=12 SPECIAL: TEMPLE GUARD:=20 TALISMAN OF PROTECTION;JAGUAR STANDARD COLD ONE CAVALRY:=8 HUANCHIS BLESSED TOTEM WARRIORS OF CHAOS: LORD ON JUGGERNAUT;MARK OF KHORNE WARD SAVE +3 REGENERATION AND SWORD OF RENDING WARRIORS OF CHAOS=12 MARK OF KHORNE; KHORNE BANNER (or something that makes them not lose frenzy) MARAUDERS=20 WARHOUNDS=10 KNIGHTS OF CHAOS= MARK OF KHORNE KHORNE BANNER
LIZARDMEN LIST SLANN:Focus of mystery,higher state of consciousness,trancendent heALIng,unfathomable presence You don't need nearly so many powers on him, as a good minimum Focus of Mystery + Focused Rumination is all you need. You can use Becalming Cogitation if your fighting someone magic heavy. SKINK PRIEST: ancient stegedon engine of the gods level 2 This is ok, I like to give him Plaque of Tepok and Wardrums of Xahutec, but the plaque isn't required. The Wardrums I would say is though. CORE: SAURUS:=20 spears This block is fine. SAURUS:=16 spears This unit would be better as 15 saurus, or 12 ranked 6x2 would work. SKINK SKIRMISHERS:=12 This unit is fine, but you could drop it down to 10. SPECIAL: TEMPLE GUARD:=20 TALISMAN OF PROTECTION;JAGUAR STANDARD You don't need the talisman or jaguar standard. You could make your slann your BSB with warbanner if you want. Plus you should drop the temple guard down to 16, you'll still rank 5x4 and the block will still be very solid. COLD ONE CAVALRY:=8 HUANCHIS BLESSED TOTEM You definately need to drop these guys down to 6, they don't need to be any larger then that. And I usually use warbanner with them, which you should do if your slann doesn't take it. Sorry if I wasn't to detailed on why to take certain things, I'm multi-tasking. Good Luck in your game...
Uhhh... For your slann Cupped Hands of the Old Ones isn't bad, just a little expensive. One or two dispel scrolls is useful. Some people like having powerstones for a little extra kick. It depends on the type of army your fighting..
I'm guessing its a k'hornate army then? He'll have magic resistance on alot of stuff, but I don't think it'll be that bad... In that case, you could save points and just give your slann a powerstone or two, that way in a critical magic phase after his dispel dice are used up you can suddenly blast him with extra dmg. Of course his magic resisitance still goes off, but you should be able to beat it with the 2 dice from power stone and +1 from slann ability. He almost doesn't need any magic items though, or at least, I usually only take a few defensive things, so maybe I'm not the best one to give advice on offensive items. Since you'll probably have alot of points leftover, look through the items and consider something you'd like to have specifically. Idk Rod of the Storms maybe? Blood stattuette of Spite? Bane Head? It's kinda up to you, I think most things work.
khorne doesn't give MR for WOC, that's daemons you're thinking of. A slann with metal is the way to go. Bane head is a must! Even without power stones as long as you cast spirit of the forge on 4 dice (3+1) you can enjoy watching his warriors and knights melt. use skinks etc to dance around his tiny army.
Well yeah, But all he said was Chaos, and idk my brain says Daemons if you don't say "Warriors of Chaos". My bad?...
I remember when Chaos meant EVERYTHING Chaos, not 3 or 4 different books. Ahhh, GW and the never ending quest for more money.
my friend changed his list he said he was gonna add be lakor and two level 2 wizards with everything else except the korne lord on juggernaut
