Need help
Discussion in 'Painting and Converting' started by Gator, Apr 15, 2011.
  1. Gator
    Gator Member
    I'm a beginner painter and I'm not sure what would be a good wash to use on my yellow skinks. I really want them to look bright and vibrant. Any help would be greatly appreciated!
  2. n810
    Try Griffontone Sepia. :)
  3. asrodrig
    asrodrig New Member
    If you want them to be bright and vibrant, then you should make sure the wash flows only into the recesses, without staining the main color of the Skinks. An easy way to check this is to give them a good coat of gloss varnish before you apply the wash - it won't stick to the surface as well, and it will pool up in the recesses.
    And if you want to keep it bright, then I also recommend Gryphonne Sepia. It's a much more lively color than Devlan Mud.
  4. Gator
    Gator Member
    The only varnish games workshop carries is matt varnish. Would you recommend this one, or is there another one I could pick up at home depot?
