8th Ed. New to warhammer, first things to get.
Discussion in 'Lizardmen & Saurian Ancients Army Lists' started by TurtleDogg, Apr 9, 2015.
  1. TurtleDogg
    TurtleDogg Member
    I am thinking Saurus old blood and saurus warriors. I am on a bit of a budget. Do you guys think I should get Scar vet? Is he still on the store becaus I only see him with battle standard. Loving the forum, this is my first post. Thanks.
  2. n810
    If you can save up, the battalion box is a good place to start. ;)
    TurtleDogg likes this.
  3. TurtleDogg
    TurtleDogg Member
    Yeah but I kinda need something smaller because I am doing a tournament so I need a leader and warriors.
  4. n810
    must be a small point tournament... o_O
  5. TurtleDogg
    TurtleDogg Member
    I'm building it up, this month is a leader and a unit. Next month is another unit and then next month another unit etc.
  6. n810
    ok, you just need a unit of Saurus then,
    You can convert one to be a Scarvet or Oldblood,
    the kit gives you a good amount of extra bling for hero's.
  7. TurtleDogg
    TurtleDogg Member
    Is converting easy? I would rather just get a old blood normally.
  8. n810
    your battle standard bearer can't be your general.
  9. angelosfernando
    angelosfernando Member
    Try ebay,get some skink skirmishers and a skink priest for magical support.Skink skirmishers are one of the best unit for a small game,hard to touch,fast and very maneuverable.
  10. Iskander
    Iskander Active Member
    Unless it's a Slann, no?
  11. n810
    Yea Slanns are the only exception in all of Warhammer.
    (as far as I know)
    Iskander and TurtleDogg like this.
  12. n810
    and very squishy. :hurting:
  13. TurtleDogg
    TurtleDogg Member
    n810 likes this.
  14. n810
    Yep, there is only one skink kit, it makes javelin or blowpipe skinks.
    You can use the javelin skinks as cohorts or skirmishers.
    The blowpipe skinks are only skirmishers.
  15. TurtleDogg
    TurtleDogg Member
    Do you think i should go for a pack of skinks and a skink priest leading or stick with oldblood and saurus warriors first and get skinks after?
  16. n810
    Either is good, it really depends on weather you want to avoid combat and shoot and magic your opponent,
    or get into close combat and fight your opponent up close and personal.
  17. TurtleDogg
    TurtleDogg Member
    I think I will start with the saurus. Thanks a lot!
  18. TurtleDogg
    TurtleDogg Member
    Hey, who can lead skinks? Would a skink chief be good? or a Tehenhauin?
  19. angelosfernando
    People dont usually put characters in skinks clouds because their purpose is to avoid combat and harass the enemy . they will die very easily when the enemy actually focus on them which is great because it means theres less things to damage your other stuff.
  20. angelosfernando
    Tehenhuain is mandatory when you're building an all skink army.Skink chiefs are glass cannons so you need to make sure to kill the enemy before they get to hit you.
