8th Ed. Noobness knows no bounds... first 2500 pts list
Discussion in 'Lizardmen Army Lists' started by thundrchickn, Oct 12, 2010.
  1. thundrchickn
    thundrchickn New Member
    New here. My friend gave me a deal on his lizardmen army which is 2 battalions and a bunch of named characters for $100. I'm inclined to take this deal as my other fledgling WHF army (WE) probably won't get an update for a while yet and they are kinda lacking in the options category that some of the other (more current) books have. So before I buy this army of his I wanted to run this past some lizardmen and see what happens and if I should plunk down on the initial investment. My woodies are for show but I want the lizards (or whatever I do pick up for my second army) to melt faces.
    2500 pts
    focus of mystery
    focused rumination
    cupped hands of the old ones
    Skink priest
    Ancient stag (EOTG)
    cube of darkness
    3x warriors
    18 man strong
    standard bearers each
    2x Ancient Stegs 550
    3x salamanders
    extra handlers
    Now the hard part
    14 man Temple guard
    standard
    or
    let the slann run around on his own(maye give him more gear to survive on his own) and take
    2x terradon groups
    1x group of chameleon skinks
    Has anyone ran a slann out of the temple guard squad and survived? I could see the value of running him in there to protect him from shooting but having more WM harassers would be nice.
    Let me know what you think of the lists, which option is better, is it competitve in 8th, is the battalion deal a good one for an initial investment?
  2. Pwidget
    Pwidget New Member
    I'd change your font color on the names of things first... I literally can't read them without highlighting them with a cursor, kinda annoying.
    Slann - I'd add becalming cogitation, its great for stopping the enemy's magic phase, and if they don't have Book of Hoeth or Power Scroll, they're never going to get an IF cast on you. Thats HUGE.
    Engine of the Gods - I like it, cube is good.
    Your saurus blocks... I feel like they're a little too small for a 2.5k point game. I'd personally run 2x25 or 2x30 blocks, and I always take HW/S, FC. At least take the Musicians too.
    You have too many points in rare, your max allowance is 625, and you have 790 written in. I'd drop an Ancient Stegadon for sure, maybe both of them. Keep the Sallies.
    I always take the Temple Guard, I'd boost their numbers a bit to around 20ish and give them Full Command, you want the Champion there to take challenges for Flying Doom-Toad.
    The Chameleon Skinks are also a necessity for me, I run about 6-8, depending on where the points fall. I've never used Terradons, so no input there.
    And hell yes on the deal, I wish I could have gotten all that for $100. I got good deals on my stuff but thats hella good.
  3. wolfmage
    wolfmage New Member
    If you run the slann solo add the ethereal disipline, can never remember the name, and the 2+ ward vs shooting.
    Chameleon Skinks are a must.
    Ancient Stegs can vary but if running chamo skinks i run one as there are less cannons to worry about.
    Mabe add more Saurus or drop into 2 larger groups.
    Run the 3 sallies in 3 seperate units, might just be me, as is harder to pin down in combat.
    If you are running life then you can afford to drop cupped hands for something else possibly power scroll or something to boost your magic or even a dispel scroll just to be sure, 13th spell+lone/small TG Slann= crying
  4. thundrchickn
    turns out the deal was even better than I thought. He has a couple salamanders (3 i think) and a stegadon thats half built so I can build all the weapons and magnetize them. Soooooo I decided i couldn't pass that up and paid for most of it last night.
  5. Juhaaha
    Juhaaha Member
    Combine those saurus warriors (2x 30 Would be ace), and with remaining points beef up TG
    Drop 1 stega, since you got engine already, with those points take more chameleon skinks and some Skink Skirmishers.
  6. Xul
    Xul New Member
    running a slann solo is very unsafe. you can have resistance to non-magical attacks, but you will lose combat to a ranked unit anyway. then fail the break test and you are done... of course you can take the crown of command to be stubborn, but that's points on top again and you can still fail. sticking the additional points into TG is really a better solution.
  7. thundrchickn
    New 2500 list is lookin more like
    focus of mystery
    focused rumination
    Skink priest
    Ancient stag (EOTG)
    cube of darkness
    2x warriors
    28 man strong
    3x salamanders
    Regular Stegadon
    20 TG
    Champ
    Banner
    Musician
    2x chameleon skinks
    10 man
    a set of terradons
    no exact number as I don't have my book with me but it's really close.
  8. Juhaaha
    Juhaaha Member
    IMO solo slann works well too. And it needs more gamingskillz0rs to play slann as solo
  9. rammramm
    rammramm New Member
    Since it seems like if you want the list to be competative i have to say that you should drop the skink priest and the EoTG. The prieest wont do much difference in either magic phase (assuming that you dont roll all that risky with you Power and Dispel Dice) and by adding becalming cogitation I think you will shut your opponent down more efficiently than with the cube.
    I would also make the chameleon units smaller since I find big units give nothing but might accually force you to deploy poorly if you opponent uses upp most of his tableedge. Imo you should only use groups of 6 or 7 (many people might disagree with that though). So I would go with 3 groups of 6 or 7 instead.
    Salamanders should be split up inte 2 or 3 groups as been said before. More targets on more locations equals more panic-tests and bigger problems for your opponents (save for chaos and undead (hate them)).
    The biggest change though should be adding a BSB to your slann. In 8th BSB:s are vital and they will save your ass on multiple occassions.
    I allways put in a bane head (targeted at the enemy wizard for when my cupped hands come into play) but thats not compulsory.
    Since the FAQ as far as I understand has said that the standard of dicipline can be used to boost a generals inspiring presence i allways add that (soooo cheap) to the TG unit for a ld 10 rerollable 12"" bubble.
    Lastly I love the ancient steg for impact hits and thunderstomp at str 6 but thats personal.
    Other than that i think it is a solid build (know that I made many suggestions but I think some of them might be apreciated) with key elements covered.
    Have fun with you newfound army and enjoy wiping the board with your opponents once the servants of the old ones are on the marsh.
  10. ancient stegadon
    ancient stegadon New Member
    my english is not verry good but if you mean with (safe for chaos and undead) the cause panic checks at them then i want to tell there imiume to psygology ;P.
    also wanted to say this is true,i esspecialy find the rerol very nice it one time let me rerol a panic test one 1-1 i think it is called snakeeyes or so (can't remember) but anyway it might even have saved to game for me ;P
