8th Ed. oldblood build
Discussion in 'Lizardmen Tactics' started by forlustria, Jan 23, 2013.
  1. forlustria
    forlustria Well-Known Member
    which of these do you prefer?
    oldblood
    hide of the coldones
    glyphnecklace
    voff
    halberd
    this guy is t6 with a 2+armour save and 5+w with 5 s6 attacks
    or
    oldblood
    hide of cold ones
    talisman of pres
    warriorbane
    shield
    this guy has t6 with 1+armour save 4+ ward with 5 s5 attacks (characters/monsters lose attacks per wound caused)
  2. Ferocious
    Ferocious New Member
    fencers blades
    glittiring scales
    talli of preservatoin
    givin him ws 10, -1 to hit, 1+sv, 4+wsv
    6 str 5 attacks :)
    or sword of might, armour of destiny, dawnstone
    for a 1+reroll, 4+wsv, 5 str 6attacks
  3. Hebus
    Hebus Member
    This one is sexy!
  4. forlustria
    how does the top one give him 1+sv (4+scaly skin and 1+ for glittering scales makes 3+) not to mention that is above his 100 point magic allowence.
  5. Hinds
    Hinds New Member
    he is probably thinking he is mounted on a Cold One :)
  6. Ferocious
    has to tallie of endurance, 5+wsv, yea he is on cold one, cant see a reason to play a oldblood on foot? :')
  7. forlustria
    reason is to fit in a semi decent slann aswell.
    sorry you posted tali of pres and 4+ws which would take him over his alowence. but tali of endurance works.
    i like your other build better though (sword of might one) give him a shield and he has 1+ reroll 4+ws without the coldone
  8. Ferocious
    yea it works for me :) but i play death/shadow and rarely life, so he gets an extra boost due the magic, making him really unstopable :)
  9. Phenatix
    Phenatix New Member
    Hi guys, I just registered here to post this. I really love the Saurus characters, especially mounted. I was considering today the whole Trickster's Helm vs Armor of Destiny debate, and decided to just mathhammer it out to see what's best where.
    Anyways, here's my find:
    WHFB 1+ Armor Save Protection.xlsx (24 KB)
    https://mega.co.nz/#!tQhSXZQT!IPQ2OThPzNiXxuDooTj2ukPsUh1iXCNu-vbrOs4D_8c
    A bit predictable, but I like now that I can see which strength ranges the different items are best against. The values in the tables show the chance for a single hit at the given strength to cause a wound (assuming it's already hit, since neither armor affects that).
    As to Oldblood builds, I really want to try running the following:
    Oldblood @ 455/457 pts
    -Carnosaur
    -Armor of Destiny
    -Dawnstone
    -The Other Trickster's Shard
    -Biting Blade/Great Weapon
    This guy is aimed to take out elite infantry. With the 1+ rerollable armor save, 4+ ward save, and denying the opponent ward saves as well, he is a beast in combat. I know many people give the Carnosaur hate, but the model is too cool to pass up (I don't mind the D3 wounds either). You could give him a great weapon if -3 to armor saves isn't good enough, and it synergizes well with the Carnosaur's Thunderstomps. Since he's the only model in our army with a shot of ever striking first, -3 is good enough for me, as I will enjoy (potentially) striking before my opponent for once.
    Another interesting build is the 9 attack monster, as follows below:
    Oldblood @ 275/455 pts
    -Cold One/Carnosaur
    -Sword of Bloodshed
    -Carnosaur Pendant
    -Gambler's Armor
    Roaring out of the gates with 8 S5 attacks at WS6 and I4, this guy can add a lot to a combat vs some low toughness opponents. He still gets that 1+ armor save, but no rerolls, and this time only a 6+ ward. 'Tis the price you pay for so many attacks, and who doesn't love to bowl nine, yes NINE dice when their single model attacks. You could pair him with a Carnosaur for potentially 14 attacks off one base, 9 WS6 S5, and 4 WS3 S7 causing D3 wounds each. This build is considerably less survivable than my first, but options are always nice.
    Lastly, you could throw this guy into a horde you want to hold up for a while to get off some nasty flank charges or something along those lines:
    Oldblood @ 275 pts
    -Crown of Command
    -Trickster's Helm
    -Sword of Striking/Talisman of Protection
    -Cold One
    Since he will probably be charging a unit alone, you may want to consider the Talisman of Protection for that little extra bit of protection with a 6+ ward save. He'll be getting a 1+ armor save though, and since the plan is to chuck him at a block of infantry, you may also consider the Sword of Striking for some 2+ hits with his 5 S5 attacks. The extra hits may also help him with a little combat extra combat res once your flankers connect. With the Crown of Command and Cold Blooded, he should be able to hold in combat for at least one round (especially if you hit the enemy unit in the flank to begin with). Against S3 or lower enemies, they will need about 217 hits to even put a wound on him, while S4 will need ~54 and even S5 would have to hit him about 12 times.
    One thing I forgot to include on the table is effectiveness of each item/combination against killing blow, allows no armor saves, and allows no saves of any kind attacks.
    I've reorganized the spreadsheet and added tables for Killing Blow, Allows No Armor Saves, and Allows No Saves Of Any Kind. What I've discovered from this now is that the Trickster's Helm with a ward save is incredibly powerful, so I will be adding a table comparing it against itself with the Talisman of Preservation, Endurance, and Protection. I want to see how far the Trickster Helm can go.
    Here's the link to the updated spreadsheet, I also replaced the link at the top of my post.:
    I finished the spreadsheet and have updated all links to be the correct version. Once again, I will outline what this document shows. Assuming the opponent has already hit you, each value in my spreadsheet shows the chance that a single hit at the given strength value will wound an Oldblood (or Scar-Veteran, or any 1+ armor save model with T5) armed with the equipment displayed at the top of each column. The general trends are as follow:
    -Against S1-S4, the Trickster's Helm is better than Armor of Destiny. They are equal at S5, and from S6-S10, the Armor of Destiny is better protection.
    -Against Killing Blow, Allows No Armor Saves, or Allows No Saves Of Any Kind type attacks, the Trickster's Helm is generally better.
    -The Armor of Destiny + Dawnstone is the best combination in many cases, except those where you expect lots of Killing Blow or (armor) saves to be ignored. This leads me to believe that the Trickster's Helm with either the Talisman of Endurance or Protection is a decent choice if your Saurus will be assigned to character-killing, in order to allow yourself more than 25 points for a weapon.
    Link replaced with newest version, replacing broken link.
  10. Arli
    Arli Moderator Staff Member
    Wow, Welcome to the forum. That is a heck of a first post. Please feel free to share any information that you have on lizardmen with us. If you have any questions, please let us know.
  11. Phenatix
    Phenatix New Member
    Thanks, I've updated my post a few times and uploaded the final version of my Excel sheet. I'll put it in this post too, just so it's in the last post:
    Link replaced to newest version, replacing broken link.
  12. n810
    You might want to test out the hide of the cold ones as well. :smug:
  13. Phenatix
    Phenatix New Member
    I could add that, as well as the Armor of Fortune, Glittering Scales, and Gambler's Armor.
    I've added the Armor of Fortune and Gambler's Armor, as well as reorganized the tables. Now, everything is compared together, reading from left to right by number of points. So, the most expensive setups are on the left with the cheapest on the right. When setups are equal in points, they read in alphabetical order. I also included two new categories: Average Hits to Wound, and Points per Average Hits to Wound. These show how much protection a setup offers, as well as it's efficiency.
    I haven't changed any previous links, in case someone wants the old layout. I prefer it this way though, and will add the Hide of the Cold Ones easily in this format.
    Here it is again including the Hide of the Cold Ones:
    I also changed all my previous links, since I just realized that I deleted the older versions, those links will be broken.
    Also, from my findings, the Hide of the Cold Ones is generally inferior to similarly priced options.
    EDIT: I forgot to mention that I fixed an error in my VS Killing Blow table, I was giving a slight advantage to the KB hit, which has been resolved.
