AoS Placing the Realm Shaper Engine
Discussion in 'Rules Help' started by xoid, Sep 18, 2021.
  1. xoid
    xoid Well-Known Member
    The rules for the Realm Shaper Engine state it has to be setup more then 3" from objectives and other terrain. Am I right in thinking then that part of it can be within the 6" control area for an objective?
  2. Killer Angel
    Within your territory, but yes.
    xoid likes this.
  3. xoid
    Ok, thanks.
    Does that mean any model that is in its garrison counts as contesting the objective, since you use the Realmshaper to measure where the models are?
  4. Killer Angel
    exactly!
    xoid likes this.
  5. xoid
    Ok, thanks.
    I thought that is how it worked from how I read it, but seemed like it could be really useful in some scenarios, so figured I'd check that I wasn't missing something.
  6. Kakalou1
    Kakalou1 Member
    Could you confirme me that Gotrek can garnison in ? And at the next mouvement phase he can go out from any angle ?
  7. Putzfrau
    Yes and yes!
    Exiting happens at the end of the movement phase tho, just keep that in mind.
    Bowser and Kakalou1 like this.
  8. Kakalou1
    Kakalou1 Member
    Thanks you ! And when he is in Garnison can he be a target ? I mean is there is a view or only Lumineth can shoot him ?
    I am thinking going to a 1000pts tournament 2vs2 with him, a Slaan, and 10 guards, everybody in T1 ^^ Like can they do the tactict of run and finish and 3 of each other in thé pyramide ?
  9. Putzfrau
    LOS/range is drawn to the pyramid, so yes he can still be shot as normal.
    They can not do that tactic units inside a garrison can not run :)
