Pros please help!: Base decoration tips
Discussion in 'Painting and Converting' started by Lucius Cornelius Sulla, Aug 2, 2018.
  1. Lucius Cornelius Sulla
    Lucius Cornelius Sulla New Member
    So obviously a decent looking base under a model makes it look so much better and wondered if you had any tips? Im looking to create a jungle based environment, some mini furns, moss, long grass etc but dont know where to aquire anything besides the basics! I have some dirt looking stuff and grass looking stuff, any tips and advice would be very appreciated!
  2. Aginor
    For jungle there are a few different options many people use:
    - aquarium plants. You can get them very cheap online. Don't forget to paint them though, most of them are green but don't look too good.
    - cheap plastic deco plants. Same as above
    - tea leaves. Those make great jungle floors. Also drinking tea is healthy, so the need for basing material helps you drink more. :)
    - then of course the basing materials you can buy. Grass tufts of different lengths, by GW, Warlord, Army Painter etc. Or make them yourself using a flock box.
    - natural materials like seeds or capsules of some plants, that you can dry, spray prime, and paint.
  3. Deed525
    Deed525 Well-Known Member
    As said above ;D
    I use tufts - you can get 150 bunches of various colours/styles for about £5 on eBay - just bulk buy like £30s worth and they will last ages.
    If you want to be a bit more experimental - use good old green stuff, it’s actually very easy to make your own flora (and they will be just how you want them)
    What I do is go on google - search for the style of plants you want (in this case ‘jungle’) to see what plans actually exist - find a few you like and replicate.
    Leave to dry overnight them cut/trim and add to your bases.
    Some examples could be;
    Vines - easy as hell to make (roll a thin snake like bit of green stuff and add parallel leaves to it - mark the leaves slightly with a tool and bamn done.
    Big leaf grass/banana plant style leaves - take a piece of green stuff to the size you require and squash - aiming to have one end wider then the other (leaf shaped) score the length with a tool and across the width either side of this, make 3/4 leaves of the same type and bunch together at the bases - move leaves to required angles/bends/add damage etc and hey presto a decent sized plant that looks good.
    Reeds/hot poker style flowers - create a tall thin stem to required height, add some small upright leaves at the base. At the top add a thicker rolled piece of green stuff - bamn a reed - make a few of these of varying sizes to hang close together - add a small water effect beneath them and you now have a swamp/pool effect with decor.
    Water pools - Lizardmen love water - jungles often have water in them - pools are simple to make, leave a patch of your base clear at any shape/depth required (use basing sand/stones etc for the surrounds and to hold the water effect inside,
    Paint colours where the water will lay ontop (murky browns/greens etc - (make sure to use brighter colours) add water effect ontop - let it dry overnight and add some white dry brush to bring out any ripples etc youhave in it.
    I could go on and on lol - message me for more if you like
    Aginor and NIGHTBRINGER like this.
  4. Deed525
    Just to prove how easy it is;
    10mins work - rushed because I wanted a bath ;D
    When dry they can be bent/cut/trimmed/added etc
    Can do a million things with the green stuff - there are no limits ;P
  5. Aginor
    Very useful, thanks for posting!
  6. Deed525
    My pleasure :)
