Revien said:
If you double the first wound twice you get 4
1x2=2 + 1x2=2
=4
If you end up with three aren't you just adding one wound for each effect?
I don't know the actual answer, and probably is another thing that needs to be FAQed, but I do get the maths and logic behind 3 wounds total.
Yes 1x2x2 is 4, but then you are counting the (single) original wound twice, when you should only be counting it once. 1 wound caused, doubled to two by one of the weapons, doubled to two by the ability. You now have two lots of (original woundx2) or (original wound + extra wound), so it looks like:
(original wound + extra) + (original wound + extra)
You can't count the original wound twice, since it only happened once, so you get original wound + extra + extra = 3.
Kinda confusing.. But thats how you get 3. I think there is an equal arguement for quadruple though. Each item doubles the wounds, and happen at the same time, so you get (original woundx2x2)
Though I don't really think this is the first time the situation has arisen, so I did a bit of a google search, and on direwolf FAQ they said this:
Q: Can I combine two effects that double attacks to get quadruple attacks?
A: No. The best you can do is double the base number of attacks. Anything on top of that has no effect. [WD222]
Anyone have WD 222 to confirm? Which would mean taking both would just be a waste of points..
