AoS Question of SLANN & ASTROLITH BEARER & TROGLODON
Discussion in 'Seraphon Discussion' started by winsha, Sep 22, 2016.
  1. winsha
    winsha New Member
    Hi. I just think some synergy, but I can't assure they are normally working. So, Can you check this?
    1. SLANN & ASTROLITH BEARER
    Astrolith bearer has 'Celestial Conduit' rule. It helps Seraphon Wizard can cast farther(+8"). And, Slann has many summon spells that have 15" range from slann. Can I use 'Celestial Conduit' rule for slann's summon spell to range up to 23"range?
    2. SLANN & TROGLODON
    Slann has Arcane Vassal rule. (If the spell is successfully cast, measure the range and visibility from the troglodon rather than the Slann.) If I use this rule, I can summon a seraphon unit from troglodon. Am I right?
    3. SLANN & ASTROLITH BEARER & TROGLODON
    If No.1 and No.2 hypotheses are right, With Astrolith bearer, I can cast slann's a summon spell through the troglodon, and summoned unit can be placed within 23" from trogoldon. I think, use this combination, I can catch opponent's back easily.
    Is there something wrong?
  2. Killer Angel
    Short answer:
    1. YES
    2. YES
    3. YES
    Longer answer:
    yes, the increased range and summon is a great weapon at our disposal. Even with the limitations of the General's handbook, summoning is still very useful.
    Seraphage, Bowser, n810 and 1 other person like this.
  3. winsha
    winsha New Member
    Killer Angel/ Thank you for your prompt reply and advice. It was a great help. Thank you.:D
  4. Bowser
    This is all correct and great synergy! Even if you don't use it to summon having that extra 8" from the troglodon can be a game changer. But summoning is a fantastic use of this.
    winsha likes this.
  5. winsha
    winsha New Member
    Thank you. I agree. :D
    Use this combination, we get 38"(Arcane Vassal range 15"+summon spell range 28") summon spell range from slann.
    Also, opponent can't attempt to unbind spell, because slann is so far away. (38"! )
    I'm newbie, but finding synergy like this is very fun!
