8th Ed. Razordon Shooting calculation
Discussion in 'Lizardmen Discussion' started by deeyo, Dec 6, 2013.
  1. deeyo
    deeyo New Member
    I am a bit confused of Shooting Rules of Razordon and Howdah Weapons.
    Razordon's shooting is to roll Artillery dice to determine number of shots. Then roll for hits, then roll for Wounds.
    It has 18" range.
    So Questions
    1) Does razordon's shooting gets affected with movement? Which is -1 penalty.
    2) Does razordon's shooting gets affected with Long range? Which is -1 penalty.
    3) Does razordon's shooting gets affected with multiple shot? Which is -1 penalty.
    4) If a unit is consisting of more than 1 razordon (or salamander). If 1 of them rolls misfire in artillery dice, is the other roll is lost?
    5) Giant Blow pipes can move and shoot: Do they get affected with multiple shot?
    6) Giant Blow pipes can move and shoot: Do they get affected with long Range shot?
    Bonus Question:
    7) What is the meaning of Life?
    Thanks for clarifications.
  2. n810
    It has 18" range.
    (yep)
    So Questions
    unless otherwise stated (they have quick fire rule)
    unless otherwise stated (so, yea)
    Only rules with the word "multishot" are effected by the rule. (so, no)
    (No), this was a common misconception
    Only rules with the word "multishot" are effected by the rule. (acutualy yes in this case)
    Bonus Question:
    unless otherwise stated(yep)
    42
    (because it's the ultimate to life the universe and everything)
  3. Mr Phat
    Mr Phat 9th Age Army Support
    1) Yes
    2) Yes
    3) No
    4) No, because rulewise a misfire only applies to the actual model firing. Besides: rulewise razordons are treated as if they all shot at once, meaning that a single misfire will happen simoultaniously with the succesful shots..meaning that the effect of the misfire takes place AFTER the shots are fired.
    5) no, it dosnt have the "multiple shots" rule...it just fires that amount of D6 shots (people tend to forget that a "Giant Blowpipe" is an entirely different weapon than a blowpipe.)
    6) yes
    7) The plan of the old ones.................................. what else is there?
  4. Mr Phat
    Nathan you editing trickster!
    ......oh...I guess we can now make the conclusion that 42 = plan of the old ones
  5. deeyo
    deeyo New Member
    Thank you.
    so to sum up
    Razordons gets movement penalty and range penalty, no multishot penalty. Misfire only affects the razordon (or salamander) that rolled.
    Giant blow pipe can move and shoot, affected by move penalty and range penalty but does not get affected by Multi shot.
    And meaning of life is 42 or what old ones planned or both...
  6. Ondjage
    Ondjage Member
    Razordon is quick to fire, so it does not get a penalty for moving
  7. sorrowquin
    sorrowquin New Member
    Razordons are "quick to fire" so no penalty for moving. (Can't march and shot though ,as stated in the Razordon rules)
    Razordons are not "multiple shots", no penalty here.
    Giant Blowpipes however ARE "multiple shots (2d6)" so you, in fact, do get a penalty here.
  8. Kroxx
    Kroxx New Member
    No, they quick fire, so they do not get affected by this penetly
    Yes
    No it is resolved like a grape shot
    No just that Razordon's shooting, and the skink handlers are pooled among all the Razordon's
    Yes get affected, it said Multipul shots (2D6), so it uses the multiple shots rule
    Yes they do get affect by long range, so a Stegadon that moves, shoots and is over 9" will not benefit from poison because it requires a 7 to hit (which is a 6 and then a 4+, then roll to wound) So shooting is only good if you don't move, or are within 9". Or tossing a cheap hand of glory on them to boost their BS, which even rolling a 1 will let the poison work.
  9. Pinktaco
    I just sincerely cannot find a way to use these guys efficiently. What exactly are their deal? IMO salamanders should be models who can do nasy things with big blocks and razordons then killing heavily armoured knights, chaff and other smaller units (which IMO would've actually made sense).
    They only do S4 attacks with no armour piercing so shooting at IC Knights seems futile since they'll save themselves on a 2+ anyway. Am I missing something here? Why on earth didn't they at least get armour piercing since they shoot you know.. spikes.. or barbs.. or whatever. Not only do they have to NOT miscast so with 6 of these guys you can except at least one of them will fail, but they also hit on 5+ against most target (long range + BS3). Then comes the question, what are they supposed to take out that our salamanders cannot/cannot do better?
    I mean: roll the amount of attacks (which can go both ways), roll to wound, roll to hit, wound and then armour saves. I just don't get it. For the price of 6 of these you can get 6 ripperdactyls + 2 salamanders and they'll most likely do the same a while lot better.
    Tell me what I'm not seeing because I've seen these guys mentioned before ... <.<
    **Sorry to hijack your thread**
  10. JuQ
    JuQ New Member
    I agree with Pintacko, Razordons are only good to kill chaff and they are quite an expensive tool for that. Before they were more expesive, but at least you basically hit on 4+ always (provifing target isnt behind cover or skirmisher or some spell affecting shooting).
    It's a shame because they were a reall cool miniature.
  11. rantapanda
    rantapanda Member
    Exactly, and the role they fill is already done by skirmishers.
    Cant see a reason to put these guys to the table
    Krox blocks at least have their niche but razordons.. hmm
  12. n810
    Razordons fulfill a similar role as Skinks, except they are actual decent in close combat.
  13. Pinktaco
    One razordon have the same strenght and attacks as a single templeguard. Sure they're fine but come on now <.<
  14. Mr Phat
    Razordons can move up 1'' from an enemy block, lock them in their place and still get a stand and shoot.
    salamanders cant do that
    and if the mentioned block chooses to charge and get in combat, Razordons are not necessarily certain to be annihilated
    usually skinks are.
    these guys CAN fight a bit, They ARE S5, and they DO get a stomp.
    I have proxy'ed them a couple of times and have never been disappointed.
    one rule is to never go less than 3+ though.
  15. pgarfunkle
    pgarfunkle Member
    I plan on giving them a go with the same intention, perhap using walk between worlds and hand of glory to get them into position early on and boost their BS and possibly WS and I to take hold up or maybe even scare off a large block of infantry early in the game while other units march into position.
  16. lifeasalizard
    lifeasalizard New Member
    In my experiences with them, I've taken them in units of 3 or 4. I get them right in front of a unit they can hurt (elves, marauders, dark elf non-knights). Throw my last set of dice at the big hand of glory. On average result roll, add +2 to their ws, bs, m, I. Hit on 2+, wound easily, kill a bunch of dudes. Now since the unit probably isn't going to panic, they have a rough decision to make. Sit there or try to move away, or charge in, taking even more hits than before, and have to fight ws 5 s 5 monsters and ws4 skinks that attack first against non-elves.
    It's actually pretty mean.
    Then again, I've also had them run down by demigryphs and magic'd off the table. But thats because my opponents had the shenanigans happen to them before and knew what to expect. (and poor play on my part!)
  17. Pinktaco
    That's fine, but for the 276pts they cost you can either have 7 ripperdactyls, an ancient steg with engine, 9 COR 2 x 10 cameleon skinks, 40 skink cohort with poison, 24 saurus warriros or whatever you feel like.
    Obviously this can be said about every unit, it's just that for what they do I'm not so sure they're that great. Hand of Glory is fine, but what happens when you poll off wyssans wildform on either the rippers or the saurus warriors? Then again non of those can shoot, but I still find razordons to be lacking. IMO they should've had Armour Piercing. Not only would it actuallyfit with with their fluff (I mean they do shoot spikes, right?), but it would make them able to actually hurt tougher units, such as knights.
    We don't actually need Razordons to shoot at neither redirecters or large blocks of weak troops. If they had AP they could've been hunting knights, especially those with an armour save of 2+.
    That's just my opinion of course and if you're having fun with them then by all means do continue.
  18. VampTeddy
    VampTeddy Active Member
    None of the units you just mentionec comes with a 5+ skink save, nor do they have skirmisher rules, and only the stegadon posses a stomp, at the trade of 7 wounds, that will have more attacks untill it loses 2 razordons, and an average same amount of stomps with -1 to str. They cause fear like most stuff in your example and are actually cheaper than your example since you won't be needing to pay for extra handlers in large units.
    They do a lot of things, and they do them rather well if i should say so. Comparing points to some of your stuff and looking at what the unit does i'd certainly say they can outperform some of those choices in some roles, while being outprformed in others.
  19. olderplayer
    olderplayer New Member
    A Razodon has to roll to hit and, unless a hand of glory boosts its BS, it will hit at best using BS3 50% (in close range) of its shots with an average number of shots of 5 (plus 1/6 chance of eating a skink) in the normal shooting phase and around 6 shots hitting on 5+ or 6+ depending on short or long range in the stand in shoot phase. Against some of the 1+ AS and high armour save models and units becoming common, razordon shooting just doesn't do enough , nor does skink shooting for that matter.
    As I posted elsewhere this week, razors are kind of squeezed out of the army list by better options to fill the same roles:
    On shooting: There is no poison, so they must roll to wound at S4. Most of the time they will be hitting on 5's and 6's unless one spends a hand of glory cast on them. That means 1 to 2 hits on average per razor and on average 1 wound which may or may not be saved. The problem is that you can end up with no shots and eating skinks to 10 shots from a single razor. A unit of 3 razors will eat one skink on average per shooting phase. I'd take S3 with poison over S4 without poison, especially with the utility of march and shoot of skirmishers allowing one to get better into range and avoid certain charges or being targetted. If you just want to stand and shoot and move and shoot to take out chaff and take on and redirect charges and movement or deter charges and screen stuff, then I think 10 skink skirmishers with javs will do better on average just becuase of the poison and guaranteed 10 shots (at least until they die). They will die faster but also have far more wounds and the same armour save. Razors have effectively 4.5 wounds with the monster and handlers rule 5+ allocation of unsaved wounds to the skinks but even that only goes so far and taking a monster reaction test at LD4 cold blooded is likely to nerf the unit's effectiveness. A skink skirmisher unit has 10 wounds with the same armour save and a parry save in combat but dies faster at T3. However, some lore of death spells witll take out razors real fast. If the razors get targetted, which they should, by magic missiles, certain direct damage spells, and certain shooting (when you don't have things like stegs or carmosaurs or basti's) then some more skink handlers wiill go down with the allocation of some wounds to handlers and one can end up with no handlers and a monster reaction test or will require a panic test if one loses just one razor even in a unit of four.
    In combat, a base razor gets only 2 atacks at WS3 and S5 and maybe a stomp at S5. S5 is great but not with only 2 attacks at WS3, it is not much. The 3 handlers, while they live, have WS2 and S3. The monster and handlers rule makes the model almost equivalent to having 4.5 wounds (as long as one has the handlers alive). I really struggle with some point of refereence as to what one would pay for the razor as a unit to deal with chaff and act as a chaff/redirector unit without the shooting. Remember that one can buy in this army a scar vet on a cold one with light armour and shield for just a bit over 100 points with 4 S5 attacks at WS5 and 2 S4 attacks at WS3 with LD8 that has stupidity (which is almost a benefit at LD8 given the ITP), 2 wounds but with a 1+ AS.
    All in, I might pay up to 45 points for a single razor witout the shooting given alternatives, but the best alternatives also have interesting shooting options. and the shooting abilities are probably worth enough to justify spending the points if I have the points to spend left over. There are some armies where I would pay even more points for what a razordon does, but not LM where one can have decent chaff and shooting out of the core slot and has salamanders as an alternative. Thus, a razor, in simulating game scenarions, ends up being a fair value. But does it fit a role that another unit cannot perform that is already in the army list? If I want a chaff unit or redirector unit, I can get ten wounds with 10 WS2 and S3 attacks for a lot less with a shkink cohort with a parry save, that unit has a chance of holding due to being steadfast at the end of combat when facing an unranked unit or skirmishing unit given that often 5 will survive the first round of combat. against light unitts. I would also be willing to spend 40 to 50 points on 10 skink skirmishers without shooting in the core slot. and can get 10 skink cohorts with shooting in a ciore slot for a cheap price. If I want quick to fire shooting and movement flexibility, then skink skirmishers with javs will do usually be a much better choice for the points, especially when dealing with most monsters, light cav, ligh chartiots, chaff units, and war machines. Against larger ranked units, both skink units and razor units will likely lose combat and flee or die anyway. The skink units, with ten models, have a greater chance of surviving with enough models to flee and maybe play some role later on or at least not given up VPs so easily or force a pursuit that exposes the larger unit to something I want to kill. Additionally, I can get those benefits in small packages, whereas running the razors in larger units makes them a target and too many VPs to fit in the army list given the core minimum and characters and othre units I want to/need to run to make a balanced all-comers army.
    A salamander, properly placed, will often get its firee thrower shot off and there is no roll to hit and no long range penalty. But it does not get to stand and shoot. With horde units so common with elite infantry and some regen (lore of life especially being common), the utility of a mobile fire thrower is something worth considering in the army. I figure on average a sally will get 4 to 6 hits with sometimes a much larger amount and occasionally nothing. Thus, a salliy will do a lot more damage on average when it shoots but will get to shoot about half as often as a razordon will get to shoot. Any unsaved wounds leads to a panic check due to the fire thrower rules (per the LM book and BRB). Sallies are potentially winners and far superior to razors against the most competitive builds for a number of common armies [skaven (slaves, plague monks, giant rat "dart" units, and clan rats), lizardment (saurus, temple guard, and even skink units which are vulernable to panic and templates with the loose formation rules), daemons (plague bearer blocks, khorne bloodletters, and beasts), high elves (white lion hordes, spears and even archers later in the game), dark elves (corsairs, dark riders, witches, executiones , and black guard), vampire counts (zombies, skellies, ghouls, grave guard, even crypt ghouls to deal with regen), infantry heavy empire (halberdiers and great swords), tomb kings (skellies and tomb guard) bretts (flame template down a deep bret cav unit)], Against monsters and solo models (chariots, eagles, for example), sallies are only going to do at most one wound, which really limits their utility and is the way I often dealt with them playing against LM. Given the new points cost of sallies and the loss of march and shoot ability, I view them as fairly priced and useful but no longer undercosted and no longer as essential to the army as they were in the old army book but in small hunting units they can still decimate the large elite infantry blocks and light cav units many common and most competitive armies run.
  20. Pinktaco
    1) About skink save - I'll give you that, although I did mention steg with engine so that's a 6+ save lol.
    2) the steg might trade wounds to stomp, but also comes with a Multiple Wound (D3) S6 impact hit. Not to mentioned T6 vs T4 and AS 3+ vs 5+. IMO I'd rather trade the steg w/ charge vs 4 razordons in terms of close combat.
    3) It is not true about the skirmisher rule. Both cameleon skinks and ripperdactyls are skirmishers. I could've also mentioned regular skink skirmishers which would've been close to 4 units of 10, but yeah.. I don't see a reason as to why I would.
    4) Razordons are weird in combat. You (and others) praise them for their decent CC stats and yet they (the models) act like 4 templeguards with lower WS, a lower armour save and more wounds. We don't ever take 16 skinks in a corhort without poison to actually kill anything so why would we even think about it with the razordon and even bother to account for them? They also lack any decent defensive capablity. I mean the beasts have WS3, T4 3W, AS5+ and the skinks are WS2, T2, 4W, AS6+. I assume you can decide who to kill in close combat, right? So as I said, I find them sort of weird in CC. I suppose the biggest draw to them in CC is that, with extra handlers, they come at 28 wounds - if we assume there are 4 of them.
    5) TBH I don't care too much about fear. It almost never goes off since most units will, in one way or another, come with Ld8(+) and have a BSB nearby. It's neat when it goes off, but I wouldn't actually be too bothered even mentioning it.
    6) removing 16pts due to the handlers is a moot point, but fine lets say they come at 260pts. We can easily remove the engine on the steg and still have an equally as capable steg, remove one ripperdactyl and it's basically the same and the same can be said for the other units I mentioned. Removing 3 skinks in the cohort unit with poison won't suddenly make them useless. Sure the razordons are cheaper, but come on...
    7) I already preemtiplely said that you can always say switch units around for the same points spend. The point is though - for 260(276) you can IMO get something that's better. I do, however, believe it's a matter of preferences.
    Ultimately though this is just my opinion. I've looked long and hard on our book and when deciding what I'm going to spend my points on it won't be razordons, not when we have so much else I rather use. The funny thing is though that this is strictly my opinion. If you can manage to get some milieage out of them then as I said to the other poster - by all means go ahead and use them. In fact I probably shouldn't even write all this because I'm a person who can decide to have 8-10 kroxigors in a unit. Something which most on this board will probably laugh at. :D
