8th Ed. Rule Clarification
Discussion in 'Lizardmen Discussion' started by Gator, Apr 16, 2011.
  1. Gator
    Gator Member
    Does a slann get a look out sir role against spells that use templates?
    Also is the look out sir role 2+ when he's in the unit?
    Thanks a lot!
  2. Arli
    Arli Moderator Staff Member
    Yes to both questions.
  3. Gator
    Gator Member
    Sorry, do you know where you can find this in the BRB?
  4. Caneghem
    Caneghem New Member
    If you look at the section in the back, where it has a chart of every model's "troop type", the slann is listed as infantry. Therefore, being in an infantry unit he gets the 2+ LOS.
  5. Gator
    Gator Member
    I see that, but in the BRB it only explains Look out sir for champions on page 93.
  6. Yakhunter
    Yakhunter New Member
    It's the same for the Slann and if you check out page 39 (I believe, maybe 36?) you will see the rules for the vortex spell type which characters also get look out sir rolls for.
  7. Caneghem
    Caneghem New Member
    Yeah, it's laid out a bit weird. Page 99 under "unusual shooting attacks" should clear it up.
  8. Gator
    Gator Member
    That does help out thank you. It also got FAQ'd, just found it.
