I was thinking of a possible combo for Saurus Cavalry, and was wondering if anyone has tried something similar. I was thinking Scar Vet - Sword of Strife - enchanted shield - Potion of foolhardines - cold one He will have 6 basic attacks plus one when he uses the potion. 6 Saurus Cavalry - Full Command Now the combo is using this with Bironas Time warp. On the charge they will have the possibility of having 27 strength 5 attacks from the rides, and 14 strength 4 attacks from the cold ones for a total of 41 attacks that are also always strike first. Add speed of light to the mix, and you're hitting on 3s that are re roll-able. Of course all the stars have to align for this to happen, but not much would be able to stay alive from this. If the opposing unit somehow survives, strap them with the Jaguar Standard and run them down quite easily.
Had somthing similar used against me but not exactly. Time Warp and Speed of Light on unit 10 CoC w/ Razor Banner with 3 Scar-Vets on Cold Ones with Great Weapons. Turn 2 it plowed right into an ancient stegs and chrushed it then over ran into my EoG and crushed it was BRUTAL!
even skinks will be brutal if buffed with all those things. the point of a "combo" is a case where 1+1=3
Well i used similar death star only with 3 scar vets some were with GW other with magic weapons to get alot of atacks. and it worked wonders with lore of light one all turney fights exept one for 1st place when slann got toasted on the first spell
