So I've been doing some analysis against out similar based R&F units and some that are 20mm. (Saurus are 25mm)
Disregarding the similar 25mm R&F units since they will have the similar amounts of models attacking each other...
If you are pitted up against 20mm based models:
5 wide = 7 of them in base with you
6 wide = 8 of them in base with you
Generally we are tougher than most units out there with T4 and we also have a good amount of attacks at A2. 5 wide would offer more ranks but 6 wide offers 2 more attacks from the front and 1 more from the back while allowing the enemy to get 2-3 more attacks on you as well. However it may be an acceptable trade-off since you are tougher than most 20mm based models.
What are your guys thoughts on this?
