AoS Save rolls on model with degrading save
Discussion in 'Rules Help' started by MackiMac, Dec 8, 2020.
  1. MackiMac
    MackiMac Well-Known Member
    Let say a Bastiladon get hit with a bunch of attacks that all hit it at the same time from the same unit.
    Do you:
    1. Roll each save roll separately and when enough attacks get through you use the worse save roll requirement for the remaing rolls?
    Or
    2. Roll all saving rolls att the same time, with whaterever save characteristics is active at the time?
  2. Bartuk
    Bartuk Well-Known Member
    It's 1. 2 is just for speeding up games. :-/
  3. rychek
    rychek Active Member
    I was under the impression that all attacks happen at the same time. Why would the saves happen sequentially? Is there a FAQ that states the saves are sequential, thus modifying the save value? I didn't see anything like that in the Seraphon or Core rules errata or commentary.
  4. Bartuk
    It is in the core rules.
  5. Imrahil
    This refers to attack sequences in which all characteristics (to hit, to wound and save) match.
    When rolling for saves you should, in my opinion, roll them one at a time to determine if the degration has kicked in.
  6. rychek
    Multiple Attacks section disagrees:
    So if the choice is made to roll the attacks all at once, then the wounds and save are all rolled at once as well. Otherwise everything is rolled one at a time.
    Bartuk, Imrahil and Putzfrau like this.
  7. Putzfrau
    This is the correct answer IMO. All the dice are rolled together throughout the process.
    Canas, Bartuk and Imrahil like this.
  8. Bartuk
    Yes but it says: "you can" in the core rules. So the oposing player can choose not to do so.
    Sure he has to roll every dice one at a time (or speed up because it make no difference.)
    But he can let me roll each save roll seperately.
  9. Putzfrau
    Allocating wounds isn't part of resolving attacks. The bastiladon, fast rolling or not, doesn't actually take that damage until you've gone through all the attacks.
    You allocate the wounds AFTER determining damage for all attacks, which is after saves.
    ILKAIN, Canas, Imrahil and 3 others like this.
  10. Bartuk
    20201211_200845.jpg You are absolutely right! Thank you!:kiss::writing:
    Imrahil, chefofwar, MackiMac and 2 others like this.
