forgive me for starting this topic if there already is one but one simple question how does the sharpened horns on the steggy work ? does each impact wound do d3 wounds?
yep, that's correct. If the unit had only one wound per model, the multiple wound roll is not used, as you can't wound the model more than once. Ace vs multi-wound enemies though!
thank you prof ! so its not use against normal rank and file infantry ah well it would be too op else good for killing those empire demigryphs and stuff !
