Skink Priest tips
Discussion in 'Painting and Converting' started by Herr Pete, May 23, 2015.
  1. Herr Pete
    Herr Pete Active Member
    Hi there,
    I wanted to start a separate thread for this so I hope that's okay.
    I've started my Skink Priest but I am looking for some tips on how to blend the colours on the Plumes.
    I'm wanting stay with the typical colour change of red-Orange-yellow-green-blue
    What's the best way to go about it :)
    Cheers guys
    Pete
  2. n810
    This should give you the general idea ...
  3. Herr Pete
    Thank you very much. Much appreciated.
  4. n810
    Oh here's part one, apparently this was for painting a sunset.
    Herr Pete likes this.
  5. Crowsfoot
    When your blending add a retarder to your paint to slow it's drying time.
    Use 2 brushes, paint both colours and have a damp brush ready, as soon as the 2 colours are on get the damp brush and move the edge were the paint meets until you get a smooth transition of colour, the trick is to keep a wet edge hence the retarder.
  6. n810
    Never had a lot of luck with that method.
    I prefer just mixing the paint as I go along the surface. (like the first video)
  7. Crowsfoot
    Both work but your method is the easiest to learn and the fastest to apply.
    What kind of retarder do you use? Where can it be purchased? Does GW carry it?
  9. Crowsfoot
    Herr Pete and NIGHTBRINGER like this.
  11. Herr Pete
    This is all superb info. Thank you all :)
  13. Crowsfoot
    Depending on what your doing, base coat 5/1, first layer 5/1 second layer 4/1, highlight 2/1.
    If you want to give blending a go try 3/1 and keep the mini away from any heat source.
    There is another technique called feathering were you apply your layer on to dry paint and just feather the edge of the wet paint into the dry coat, it takes some practice but another technique in your cap, just tried edge highlighting for the first time last night on my steggy!
  14. Caprasauridae
    Sorry, @Crowsfoot, but can you expand on that a bit? I don't really understand what you mean by feather the paint.
  15. Crowsfoot
    Ok say your doing layer one over the base.
    Base coat is dry and usually you do layer one and you just leave the edge of the layer close to the base coat (as I do on all my models), you could take your brush wash it and then right at the edge just wiggle the paint thinning it were it meets the base, doing this without a retarder could and usually does leave a line were the paint sat before you started to move it around, the technique could be called something else now.
    I used to do this for models I wanted to show off.
  16. Caprasauridae
    Ok, I just tried that technique, but it was called 2 brush blending, as you use one brush for painting and other clean, damp brush for pushing into the paint front and then wiggling it away from it, dragging some now diluted paint with you and creating blending. It's difficult, I can't really do it for small surfaces.
  17. Crowsfoot
    Yeah it is hard but can create a lovely blended model but again probably going to far for rank and file models.
    I've obviously got confused over the years as both techniques I've mentioned are basically the same :wideyed:
  18. Caprasauridae
    Many techniques have multiple names that are used interchangeably, so it's no wonder people are confused. For example, I thought feathering is something completely different... We need a standard naming system!
    Thank you!
