8th Ed. Slann - on his own?
Discussion in 'Lizardmen Tactics' started by twistedmagpie, Sep 13, 2013.
  1. twistedmagpie
    twistedmagpie Member
    Hi,
    In my local community we usually play 1500pt games. I have been playing with skink priests and Tetto'Eko. I have been enjoying it and having varying degrees of success. However I have had advice to put in a Slann, even at this points level.
    My problem is that I can't afford a decent unit of TG, the general concensous is to run him between saurus and skink units. I'm finding this difficult because he needs to be in the front rank so the units are pretty useless.
    So is there a viable way to run him on his own in this edition?
  2. The Scottish Saurus
    The Scottish Saurus New Member
    ive had no expireince with this but id suggest giving him the ethereal discipline and a protection unit unit near him to help him out with combat
  3. Dyvim Tvar
    Dyvim Tvar New Member
    Instead of making him ethereal, give him a 10-strong skink cohort unit. Protects him from being singled out by missile fire and magic, and gives him a look-out-sir roll against war machines.
  4. twistedmagpie
    How will he fit? My guess is that he'll sit on the side of the unit because his base isn't of the same size factors (He's exactly 2 saurus wide, which is more like 2 1/4 skink bases wide). Does he still get the look out sir? I thought that wasn't the case.
  5. Dyvim Tvar
    Yes, he goes on the side because of different base sizes. Look Out Sir is based on troop type though, not base size. Since both the Slann and Skinks are infantry, he gets a Look Out Sir roll.
  6. Scalenex
    A skirmisher unit is a bit more maneuverable for only a few points more.
  7. Dog On Todd
    Dog On Todd Member
    Would this also make him a skirmishing slaan?! I love it
    Was debating trying a new combat army for my 1k tester next week, but I'm finding cowboys not as interesting against WoC, so I might go solo slann and swarm.. swarm with a bastille just to goof around
  8. Madrck
    Madrck Member
    My normal opp and I have banned lvl 4's in 1500 point games. Dwellers, Pit ect... remove alot of the fun at that lvl.
    If your set on it though a skirmisher unit is ideal as your slann will get the light troops bonus(-1hit from shooting)
  9. twistedmagpie
    So what unit size would you go with to give him enough protection. Is there any protection for a skirmisher unit from cannon fire? There are quite a few scary shooters in my general opponents armies.
  10. Dyvim Tvar
    I think a unit of 10 skinks is plenty. If you have multiple units, you can switch from one to another if the first gets decimated, and will give you more flexibility.
    The Slann will get a Look Out Sir! roll from cannon fire while in the skink unit as long as there are sufficient rank-and-file models left in it.
