8th Ed. Slann upgrade help
Discussion in 'Lizardmen Tactics' started by Kharn The Betrayer, Dec 18, 2013.
  1. Kharn The Betrayer
    Kharn The Betrayer New Member
    Is the upgrade which gives all of 8 lores signature spell worth it?
  2. NexS1
    NexS1 Well-Known Member
    It's up to you. it really depends on how you build the rest of your army and what purpose you have decided upon for your slann.
  3. Necromancy Black
    Necromancy Black New Member
    It gives you a bit of everything without getting a lot of something. Here's my thoughts:
    Fireball
    Magic Missile
    A decent magic missile and easy enough to cast, able to to from d6 to 3d5 Str 4 hits. can be very useful against smaller units like fast cavalry or flyers. Range on it is good enough that you don't really need to channel it through skinks.
    The only way you'll get anything out of the Lore attribute would be from taking the Ruby Ring of Ruin and using it to shoot a fireball at the target first. +D3 isn't game breaking, but if you want to cast the 18+ version it can be good.
    It's also flaming, so that can be or bad.
    Wyssan's Wildform
    Augment
    An awesome spell that's always good. Pretty much everything but swarms and skinks with blowpipes is a good target for this spell. Getting some skink priest with it as well to try and stack it on a single unit is also good, and the slann has a much, much easier time casting this.
    There's plenty of things in the Lizardmen army that benefit from the lore attribute, though -1 to the casting spell isn't that critical for the Slann.
    Searing Doom
    Magic Missile
    Similar to fireball but can only get up to 2d6 hits and has double the casting value.
    The real difference is the lore attribute, which ignores armour and is easier to wound the better the enemies armour is. This is essentially an answer to enemy heavy calvary.
    The benifit of having only the signature spell from Lore of Metal is that this Lore can be at times hit and miss. Against some armies there's unlikely to be more then one unit with an armour save better then 4+, and they probably have a ward save or maybe MR. In these cases the damage potential of the Lore of Metal is really decreased. But against armies heavy on the armour or that have a couple of really killy, heavy armour units then this lore is a power house.
    Basically with all the sig spells you get Fireball to take out the light armour units easily, and Searing Doom to take out the heavy armour units easily. That's some good utility.
    Like Fireball it's also flaming, so that can be or bad.
    Shem's Burning Gaze
    (Another) magic missile
    Shem's has two level, the first is exactly the same as fireball in hits, strength and casting value. The second level doesn't increase the number of hits, but ups the strength from 4 to 6 at a casting value of 15+. Basically the second version is best used on single, higher toughness models like monsters, or maybe on particularly tough monstrous infantry. Apart from that, it's another easy to shoot missile good at taking out light units, just like fireball.
    The Lore attribute comes into play against very specific enemies, but against them it gains and extra d6 hits. This is generally great against these armies, as they usually can field both small elite units and large blocks of cheap, light infantry. This spell has a version suited for both of these.
    Again, it's flaming. Regenerating enemies aren't going to be a problem for your magic phase, but anything that gets extra saves against flaming attacks (and there's a few things out there) might be a problem.
    Earth Blood
    Augment
    Gives the wizard and any unit he's with a 5+ regen. Useless for a solo Slann, but rather good in a TG bunker provided the enemy doesn't have plenty of flaming attacks. The casting value is easy for a Slann too.
    The lore attribute can be reason enough to cast this spell, letting you heal a wound on a friendly model in 12". Good for maybe getting some health back onto those monsters, great for putting a scar-vet back to full health.
    IceShard Blizzard
    Hex
    Ever since one of the first 8th edition errattas that changed the wording of steadfast, this has been one of my favorite spells in the game.
    Easy to cast for any wizard, it provides a very useful -1 on the enemies hit rolls (shooting that doesn't roll to hit will only get to fire on a 4+) and also to their leadership. Useful on nearly anything that can shoot or is about to charge a unit. One of the main weaknesses of Lizardmen is a lack of high WS on our warriors. Bringing elite enemies models down to hitting on our level (often 4+) really helps cover this weakness up. The -1 to leadership isn't so good on it's own (especially when the enemy has a BSB nearby) but like Wyssan's Wildform this is another spell that's easy to stack due to skink priests having access to it. I once managed to make a Brettonian unit run off the board with their general and BSB on turn one as my opponent allowed me to cast this spell onto the unit 3 times. A single wound from a salamander in the following shooting phase saw them take a panic check at -3 leadership and flee.
    Also, remember that steadfast and stubborn units only ignore combat resolution when taking their break tests. The negative leadership from this spell still applies so not only does it help you win combat, it helps make enough the most stubborn units break and flee.
    The lore attribute isn't bad, but often it's not worth casting this spell onto a flying unit just for the free d6 str 4 hits when the -1 to hit and Ld are more powerful elsewhere. But, if there are no greater threats around, go ahead and cast it. It's basically another fireball.
    Melkoth's Mystifing Miasma
    Hex
    Ok, very easy to case and has a ton of uses as it affects so many stats. Negative movement is always powerful as per the FAQ, even flying movement is affected which can really, really screw over a flyers ability to position itself. Same applies to fast cavalry and this can be enough reason to cast the spell itself.
    Reducing ballistic skill is powerful, as each point lost is essentially -1 to hit with shooting (provided the unit shooting cares about it's BS)
    Now, WS and I are more iffy. Why? Because generally our models have a such bad WS and I that lowering these values might not even make a difference. Against high WS and I armies like elves and warriors of chaos, you might not get any benefit from casting this spell, especially as the value you decrease the stats by is random. If you want to get hit less in combat, Ice Shard is much more effective.
    Having said that, against models that have similar stats to our warriors, lowering the WS and I is amazing. Forcing things to attack at the same time as saurus is great. Having the saurus hit on 3's is brilliant!
    So it can be situational, but never to the extent that Searing Doom is. Still a great spell.
    The lore attribute won't get used much, but it can be a Slann saver. A solo slann will use it the moment it looks like he might see combat, while a slann inside a TG block can use it too escape should all the TG be about to disappear.
    Spirit Leech
    Direct Damage
    The only direct damage signature spell! Yay, something you can use while your TG are in combat! It does have a short range though, and you can't cast it into combat, so remember that.
    Now, this is a great snipe spell (especially channeling through skinks) but there is one problem. This spell uses the unmodified leadership on the caster and the target. For us, that's a 9. Nothing in the Lizardmen army gets an unmodified Ld higher then 9, and as this spell isn't a leadership test we get no benefit from Cold Blooded.
    "So what?" you say, "I'll use it on models with a lower Ld." Unfortunately inspiring presence works for this spell, even though it says unmodified leadership (check the FAQs). So for a lot of enemies they'll have a Ld 10 general about, meaning they've basically got a +1 to the dice roll.
    Now, bad rolls can happen and you might roll a 6 to the enemies 1, doing 4 wounds that they can't use armour saves against. But the odds are stacked against you a bit.
    Now, Inspiring presence only covers so much area, often leaving the flanks uncovered. This isn't always that helpful as this spell can only wound a single model and most of the targets you want to go for with be in the general's leadership bubble.
    Having said all that, this is a great monster killer spell. Any monster that gets out of the generals Ld range should be targeted as they often have low Ld, giving you a good chance to kill it off in a single spell. Sometimes you won't have the chance to do this until later in the game, as army will often deploy tight enough to project it's expensive monsters (especially once they realize you got this spell).
    The range is short to ok, 24" on the boosted version but as the casting value is only 3 higher is makes little difference. You can channel this through skinks too, so that can give you a good long range to hit anything that strays away from their general.
    The lore attribute is pretty good, a 1 in 3 chance to get a power dice for each wound you do. Often this is only going to come into affect against the low Ld monsters you can get, but considering you could get 5-6 wounds on a single casting (and this spell is just really good at killing those kind of monsters) throwing a few dice to make sure this spell goes off can be worth it as on average you'll get a few power dice back. (just remember that on a miscast, you resolve it after the spell so any power dice you gain might be lost from the miscast)
    Summary
    3 magic missiles, all of them flaming (can be good or bad), two of which can be ok to fantastic.
    2 hex, both of which will be useful every game.
    2 Augment, one which is great, one which is fantastic.
    1 Direct Damage, situational.
    In a magic phase with a high number of power dice you can get a lot of spells, which will make it really hard for the enemy to decided which spells to stop. The trade off here is really the lack of large game changing spells. But you do have 4-6 spells that will be used all game, every game, and over the course of 6 turns will help you win.
  4. Pinktaco
    Didnt spirit leech get faq'd to work with modified Ld?
  5. Necromancy Black
    Only 2 things in the FAQ mention spirit leech: one says you befit from inspiring presence, the other that you can't use the Charmed Shield against it (as it doesn't cause hits).
    Now, the FAQ also says that Unmodified leadership can't use inspiring presence. But for spells it specifically says it can, and uses spirit leech as an example.
    Absolutely stupid rulings, I know.
  6. Besty
    Besty New Member
    I'm new to the game, but I have used it in the last two games, and both times with the book of ashur (+1 to cast and dispel but exspensive) however with +5 to cast I can confidently throw one dice at the basic spells after I have drawn out the enemies dispel dice. It's very situational on how many power dice you get though, an next game I'm going to try with the 3 dice channel on 5+ combo alongside 2 skink priests for 5 attempts to channel extra power dice (and a small amount of me is tempted to give my slan the ability to keep a dispel dice an turn it to power dice in my turn) but il have to wait and see.
    Besty
  7. Pinktaco
    Do remember thoughg that you can still break concentration by rolling a one or two on the dice. So while you certainly won't IF any spells with just one dice you have 33% chance to fail that spell and not be able to cast any more in that turn (with the slann). To me this means that I'd rather try the better/bigger spells first and when you have 2 dice left you go ahead and try that.
  8. Necromancy Black
    Exactly as Pinktaco says, rolling only one dice is basically a 1 in 3 chance of ending your magic phase.
    A skink priest taking the Forbidden rod is good way to get some more powerdice for a turn.
  9. Ondjage
    Ondjage Member
    Can you actually stack several Augments/Hexes? Say Wyssans Wildform x 2 for strength 7 temple guards?
    :O
  10. Necromancy Black
    Yes, in the magic section it states that the affects from hex and augments stack. There's no rule saying this is only for different spells.
  11. Sebbs
    Sebbs Active Member
    Contrary to Besty I've used WD Slann with +5 3D6 to channel for two games. Once vs. empire, ran my skink priest forward and sniped Elspeth von Draken right off her carmine dragon turn one! :D Needless to say I had free reign the ensuing magic phases :)
    The other time was vs. deamons of nurgle, kept throwing Wyssans on my saurus and iceshard on his plague bearers to nudge the scales in my favor. What I realized was that when he was having trouble throwing away his PD on big spells only to see them be dispelled most of the time, I quickly drew out his DD.
    Remember, big spells doesn't only mean you will miscast more often, it also means that when you don't miscast, the enemy will throw more DD and might get irresistible dispel. ( I also have a nack of throwing 1's 2's and 3's when going big :p )
    With low-cast spells not only will you lower your chance to miscast but also: A) You throw few PD, enemy match with lower or equal number with DD and you have a decent chance of getting the spell off OR B) The enemy outnumbers your PD in which case you will have some PD over at the end of the magic phase.
    Next time I'm going to try Book of Ashur though! :)
  12. Kharn The Betrayer
    If I am determined to run a temple guard block is this upgrade better? Since its nearly impossible to miscast on 2 dice?
  13. Sebbs
    Sebbs Active Member
    Sure! I like WD alot already even though I haven't used it much.. yet! You'll miss out on extraordinary trick spells like walk between worlds etc. and huge doom spells like dwellers or purple sun. But on the other hand you get an easy to use, safer battery of spells :)
    If you want to mitigate miscast you could go with:
    Life: for throne of vines (there's a chance you won't get it though) plus life is probably best suited for monster mash! ;)
    Or light: pretty low cast-value spells that also happens to be the perfect remedy for some of our weak spots + of the augments you can use as AoE-buff bubble which is perfect if you keep your other saurus blocks close to your TG+Slann :)
    Great thread summarizing light --> http://www.lustria-online.com/viewtopic.php?f=15&t=9335
    I would still recommend giving WD a try, casting lots of spells is lots of fun! ;)
  14. RipperDerek
    RipperDerek Active Member
    The best way to mitigate miscasts is still: don't put your Slann in your unit of temple guard.
  15. Putzfrau
    You couldn't cast it twice from one Slann. You'd need to use the Slann and a priest on beasts to get it x2 off in one turn.
  16. Kharn The Betrayer
    I played a 3 priest list at 1500 and got off triple wissans on my Saurus block.... Needless to say they slaughtered the high elf spearman horde they were fighting
  17. Andy06r
    Andy06r Member
    Book of Ashur WD slann works great with temple guard blocks. Being able to two dice every spell or gamble and one dice means you can cast a lot. You won't get everything off, but you'll get something off. You can also take advantage of the life signature, unbreakable, and ItP.
    The Harmonic + Staff works great with a solo slann. The extra dice will let you brute force more spells and if you miscast, typically nothing happens.
    Both setups have pro's and con's and it really depends on what the rest of your list is doing.
