8th Ed. Spawning Pools
Discussion in 'Lizardmen Discussion' started by pendrake, May 6, 2015.
  1. pendrake
    How big is a spawning pool?
    Is the answer different for:
    A) a terrain piece.
    B) examples in fluff and fiction.
    I ask because I am considering building one, and question #1 is how big to build it.
  2. Arbite
    Arbite Member
    Here is what I use. It started as a belt buckle. edge was built up around it and scenic water was added.
    pendrake, NIGHTBRINGER and Qupakoco like this.
  3. Arbite
    Arbite Member
  4. Qupakoco
    A) Something 8"x4" is what I would expect for terrain. Maybe a little bigger.
    B) They should be fairly large. I'd assume they're deeper than they appear on the surface since whole cohorts spawn at once. I'd say they could be about the size of a standard short course swimming pool.
  5. Arbite
    Arbite Member
    pendrake, NIGHTBRINGER and n810 like this.
  6. n810
  7. KingCheops
    KingCheops Active Member
  8. Slanputin
    Slanputin Well-Known Member
    I'm sure I remember the fluff describing them as vast, flooded caverns beneath the temple cities.
    Most I see online however are a lot smaller. I remember a White Dwarf issue years ago with a swimming pool-esque design. It had similar dimensions to what Qupakoco suggeste. I also saw another "official" terrain piece that looked like a pond...
  9. Qupakoco
    The Saurus are born in the caverns under the temple cities, whereas the Skinks and Kroxigor come from pools within or surrounding the cities. I believe the 6th edition book has a great picture of a Saurus being "born".
  10. pendrake
    That is pretty cool. Did the original buckle have the colors in the incised lines? Was that added with paint or ink before the water effects went it?
  11. Slanputin
    Ah, I remember that picture. Unfortunately I couldn't find it.
    The Saurus always looked like it was doing a hair flick out of the water.
  12. Arbite
    Arbite Member
    the buckle was iron colored. It was painted the colors but only on the raised portions. then filled with the Scenic water.
